Tyre Inflation
Jun 20, 2017
166
I have a large compressor in my workshop at home so it’s quite easy to check and adjust tyre pressures before a trip.
Do many of you carry a portable inflation pump whilst on a trip?
Thanks for looking
Kevin
Oct 17, 2010
1,321
567
Me too, in the boot, I also have a small Stanley compressor in My garage
Parksy
11,904
2,400
Yes, It's always in the towcar with a small basic toolkit, torque wrench and sockets
Jun 2, 2017
118
29
10,585
Yes I do in the car but also a pressure tester as don't think the meter on the pump is very accurate
Mike
9,319
I carry a Michelin rotary electric compressor plus a track cycle tyre pump as back up. The van tyres are at 59psi but it’s the car tyres that require most attention whilst touring. 210/220 kpa solo and 250/300 kpa loaded and towing. When leaving a site I try and ensure that I don’t annoy others by starting up the electric compressor before 0700 ;)
Mar 8, 2017
391
13
1,685
Thanks for looking
Kevin
Yes, I carry one in my boot.
Mar 10, 2006
3,274
47
I carry a small compressor because its small in the boot, but usually top up at home using a cycle pump.
Apr 19, 2017
361
I actually saw someone using a footpump the other day. (I've got one somewhere, but it is heavy..!)
Like others, I use a big compressor at home, and have a cheapo 20yr old Halfords 12v compressor in the car.
4,672
Yes we carry an electric 12 volt, one but have seen a high pressure hand pump. For about £20.
And I now have a Tyron band portable kit. Took me 2 years to buy one.
Opening a jar of worms
Jul 22, 2014
329
I bought a footpump the other day and I'm not sure what you see as a problem. And I am one who often finds myself removing and replacing tyres from the rim and re-inflating from zero - most recently to replace all four pressure sensors. That reminds me that I still need to do the spare.
Sep 29, 2016
1,829
245
Compressor in the garage, but airline not long enough to reach the caravan, suppose I ought to buy more airline :blush:
12v electric and a twin barrel foot-pump in the car.
4,672
I use a foot pump,
Still like Dick Emery, no matter what the Fun Police say. :pprobably get dismissed for being too far off line,
Mar 10, 2006
3,274
47
I do have a double foot pump but find it hard work compared to my high performance cycle pump, the type you stand on and pump with both hands.
At Home if I'm feeling lazy I also have a power pack with a compressor.
9,319
Craigyoung said:
I use the 2o pence for two minutes machines usually at ASDA ! :p
Craig
Bit difficult when your on pitch miles from anywhere and need to increase your tyre pressures to tow home!
Apr 27, 2015
128
Yes always have a compressor in the car (plus tow rope, jump leads, and basic tools). Also use a tyrepal, which is very very handy. All I have to do to check pressures, is move the van a bit to wake the sensors up. Very reassuring if the van has been sat idle for a while, and far easer than manually checking. Amazing to see the difference cold weather makes to residual pressure (although tyre wall heating does soon bring the pressures back up).
Feb 3, 2008
3,790
I was always told to set the pressures when the tyres were cold, irrespective of ambient temp. Therefore tyre wall heating should not be relied on to adjust pressure. :(
Apr 27, 2015
128
The point I'm making is that 45 PSI in the summer can suddenly drop to 40 PSI in cooler weather (and then back up again when it warms up). If I get the van on a cold morning and the pressure is a bit lower I don't bother pumping it up as I know in general the right amount of air is in there and as soon as hit the road the pressure will rise again. Not sure it makes sense to pop another 5 PSI in there and then have to do the opposite when the weather gets a bit warmer.
