Jul 30, 2013
I've been searching google wothout n answer.. Im changing 2 tyres on my double axle caravan.. Where would be best to fit them.. On the rear axle or front ?? Thanks.. Micky
3,137
I would fit them to the axle that does most of the work. WHich axle that will be is dependnat on how your caravan tows, if its noticabley nose down, then that would be the front axle, If its level, then its even stevens, and if its nose up then its the rear set.
I recommend you only fit them to the same axle.
