- Feb 23, 2018
- 922
- 89
- 18,935
Jockey Wheel down.
Its attached to the chassis whereas my front steadies are not. Plus my old caravan did not have front steadies!
However, to make the E&P system work, the nose has to be low, to allow the hydraulic steadies to level front to back; in the process of doing so, the Jockey Wheel becomes airborne. What E&P do not say is if you need to lower it afterwards. They do say the following:
Furthermore, for their Compact System for caravans, which only levels Side-to-Side (no auto steadies, the say the following:
"...for stability."
The warranty of the caravan manufacturer is not affected by the fitting of the Level C system. Caravan manufacturers fit corner steadies to their vans in line with guidance and approval from AL-KO, who supply the corner steadies. AL-KO have tested the E&P system and given their approval for our corner steady.
The AL-KO report determined that the Level C system actually prevents too much force being applied through the corner steadies, when compared to a standard corner steady, thereby helping to protect the floor of the caravan.
The Compact caravan leveller uses just 2 hydraulic axle jacks to automatically level your caravan side-to-side at the push of a button. You then level the caravan front to back with the jockey wheel and deploy your corner steadies as normal, for stability.
"...for stability."
