- Sep 18, 2022
- 25
- 16
- 1,535
Hi, has anyone ever upgraded a 3 gas ring cooker to a dual fuel cooker? We have seen a nice new caravan but it only has the 3 rings and wife like to use the electric hot plate , thanks
Have you contacted the caravan manufacturer and asked if they could perhaps install a different cooker if you paid the difference?Hi, has anyone ever upgraded a 3 gas ring cooker to a dual fuel cooker? We have seen a nice new caravan but it only has the 3 rings and wife like to use the electric hot plate , thanks
Gas Whistling kettle, saves on GasWhy use the hob when you can have a BBQ outside or use the microwave?![]()
We used the hob and oven quite frequently especially during the colder months.Why use the hob when you can have a BBQ outside or use the microwave?![]()
Never seen the need for an induction hob in a caravan, however by the same token we use an air fryer in the caravan.Most household induction models typically have zones that range from 1200 to 1800watts or more.
Considering you only have say 3700 watts on a 16 amp EHU might prove problematic with everything else on.
Alternatively park up next to the Prof. He is an accomplished chef😉
Do you mean hair dryer🤪🤪Never seen the need for an induction hob in a caravan, however by the same token we use an air fryer in the caravan.
No point if you are bald.Do you mean hair dryer🤪🤪
Exactly what I was thinking of getting. I don't suppose you know the weight do you?We have a three burner gas hob. The hob being a little on the small size, we find that some of our pans wont fit if we need more than two burners - the burners are too close. So we bought a single electric hotplate for those occassions. Also since we've paid for the electric we might as well use that
No idea, but we use the one from home Ninja Air Fryer Max AF160UK. It is 1750w, but we have never had an issue using it on site even with 10amp.Our air fryer at home, is an early one , Tefal , and weighs a ton. Are these newer Ninja things lighter?
Different name on mine but it looks the same.Exactly what I was thinking of getting. I don't suppose you know the weight do you?
