Upgrading from Truma Ultraflow inlet and manual pressure switch
First time poster!
I have a 2019 Adria Isonzo which is lovely but as always there are some things you wish were different.
At present it has the standard (fairly inflexible) Truma pump assembly, Ultraflow inlet and manual pressure switch.
We nearly always run on battery, hook up is extremely rare for us.
I'd therefore like to both change our pump assembly to the Whale one with a Truma connector, but I'd also like to get a smart pressure switch to cope with voltage changes. All I've found online is people going either fully Truma from pump through inlet into switch, or the same for Whale. Given I'd be after a Whale pump but Truma inlet I'm unsure how to achieve this.
Any advice appreciated, I can't imagine I'm the first to ask this but sadly my searching has failed me!
I am seriously untechnical and may be totally misunderstanding your question but I believe you can get an adapter to connect a whale pump to a Truma inlet. I seem to think that we have had one at some stage of the game.
Welcome to the forum. I am sure that someone will come up with a better answer than mine.
You can get the inlet, I'm just trying to avoid changing absolutely everything. Unless the answer is that I should change everything!
