- May 15, 2023
- 172
- 155
- 1,635
I can’t’ be the first person to have this challenge:
I tow multiple trailers that all require the tow ball to be greased, and now have a caravan with an Alko hitch that certainly doesn’t want any grease contamination the friction pads!, not a problem I thought, I’ll just carry a can of brake cleaner and some paper towels to clean the ball whenever I need to tow the caravan, however because of the way I store the trailers and van, I quite often need to move one or the other and a few weeks ago whilst moving stuff around the dropped the brake cleaner aerosol snapping the thin feed neck, so had to rely on simply wiping the grease off , but knowing that I will still have contaminated the Alko pads in some way.
There are a couple of fortunate things, firstly as I bough the van second hand I planned on replacing the Alko hitch pads anyway, second bit of luck, when I bought the car new, GLE 400d in Sept 2022.
I wanted the manufactures electric factory tow bar as I’d had it on a couple of previous E class Mercs, the dealer could get me the spec of the car I wanted relatively quickly, but without the tow package, if I wanted the tow package it was a 10 month wait! So I went for the car without the tow package and the dealer fitted at Tow Trust detachable tow bar. The down side of this apart from having to store the swan neck is that with the factory job there is a 3500kg towing capacity, reduced to 2700kg when a retro fit tow bar is fitted, now as I’m not going to tow anything over 2000kg this wasn’t an issue, why was this fortunate? Well now I could have 2 swan necks, one for Alko friction hitches and one for greasy. The tow bar that’s fitted uses the ACS system as used by Whitter , Tow Trust and numerous others.
The swan neck supplied had a 4 digit code 6717, so I searched eBay and there are loads of ACS swan necks, new and used, but generally described by the vehicle application rather than the swan neck, I looked at one swan neck that was described at fitting a GLE, but it had a different part number, although looked very similar, I then looked at some Tow Trust installation instructions and found 2 different specs for the swan neck for the same year of car? , there was no joy in searching for a 6717 , so I contact Tow Trust to see why there were different part numbers and if the parts were interchangeable, I spoke to a really helpful lady at Tow Trust who explained that firstly the number doesn’t relate to a specific car, and that there would be interchangeable swan necks with different part numbers that were more related to batch production than spec change, she gave me a list of numbers that would fit my tow bar. Armed with this info I did a broader search on eBay and found a little used swan neck that was advertised for a fairly obscure car, with a low asking price, so I paid £15 for the swan neck (most are advertised at around £90-£140) . When fitted to the car the height and distance from bumper are exactly the same.
So I now have a clean swan neck for the Alko and a greasy one for everything else.
Possibly a sledge hammer to crack a nut!
