Surfer said:Prof John L said:Surfer said:As for MTPLM I keep forgetting that there is no statutory law regarding MTPLM and it is the axle weights that count,
Hello Surfer,
Ignore MTPLM/MAM/GVW at your peril.
Lutz has explained at some length that where caravans are concerned the weight limits given by the caravan manufacture will over-ride the chassis manufactures limits.
Basically MTPLM can be ignored as it is only a guideline like the 85% rule. VOSA would never use that to define whether you are legal and not over weight. They would check the plate on the axle! If you are exceeding the weight on your axle you are in deep poo poo! As it turns out the Antara is no good for us, but that is covered in a seperate post!
All these weights and be so confusing, it's easier to get the b+e!
My Antara is just brill, really liking the drive, hopefully ill pass my test then I can tow my caravan.
