Vauxhall Zafira suitable for Lunar Quasar 525?
Dai
Mar 8, 2009
Hi, I'm thinking of buying a 2008 Vauxhall Zafira diesel 1.9 CDTi 150 bhp to tow by Lunar Quasar 525. This meets the 85% loaded caravan/kerbweight recommendation, but I was wondering what anyone thinks about the suitability? Thanks, Dai
923
The MTPLM of the Quasar (2010 Model Year) is 1395kg.
The maximum permissible towload of a Zafira 1.9 CDTi 150 bhp is 1500kg, so that gives you quite a safe margin.
Nov 12, 2009
1,142
hi lutz,
you seem to have good references to matching outfits, i posted about the suitability of mine a wee while ago but didnt get a direct answer like what you have given here. so, any idea of the following, 07 vectra 1.8sri petrol, and an abbey aventura 316 ?,
cheers in advance for any answers.
Mar 9, 2008
122
hi lutz,
try this http://www.whattowcar.com/
923
If the car has a 4.19 axle ratio (which I suppose it does) it will have a maximum permissible towload of 1500kg.
According to my database, the MTPLM of an Abbey Aventura 316 is 1408kg.
923
In your last post you mention an 01 model. That would be the generation before the 07 model that you referred to before. However, I can find no model with a 1350 towload limit, regardless of whether it's a 01 or a 07. The details on your V5c should be correct, though.
923
If the MTPLM of an 01 model Aventura 316 is 1350kg compared to 1408kg of the current one, then you've got a bigger margin to the towload limit of 1500kg of the Vectra.
Nov 12, 2009
1,142
lutz, cheers buddy.
you have given me the advice i thought was about right, others have posted to my earlier posts when i first joined but most of the answers were quite technical. i have towed with this a couple of times now, and even being a newbie at the game i found it pretty easy to handle, apart from dropping down the gears on inclines. might be going for the diesel 1.9 model now.
cheers :)
923
For several years during the early and mid-90's I towed a 1300kg caravan with a 1.8 litre 90hp Vectra. It sometimes required dropping down to 2nd gear at 50mph on some hills in order to keep up with the traffic, but the car never grumbled.
Nov 12, 2009
1,142
lutz, ye have made me think of what an old seasoned caravanner up here in my neck of the woods told me about the the recommended weight margins for towing. he says that the recommendations came about years ago to give the 85% match in relation to the cars of the day. however, he says that modern cars are way above the capabilities of those from days and the power and torque they provide is more than plenty to accomodate the extra load. i think thats a good point, especially if the recommendations havent been updated.
i can vouch for how much bikes have progressed in the short time of one decade, i have always had one of the latest pocket rockets, the litre class sports bikes. each one i had seemed to take biking into another dimension, and ultimately i have one which pushes out 172 bhp at the back wheel, phenomanal progress, and cars are the same.
would be good idea if the issue was revisited and new benchmarks given in relation to the modern machinery.
Feb 23, 2010
we tow with an 08 model towing a sterling 460 at 1300kg mptl
it will pull 6 th gear easily on flat from 55 mph plus
returning mid twenties mpg
with two bikes on roof it goes up to 30mpg must disturb airflow like an aerofoil ive checked it several times and it is consistant
good luck graham
May 5, 2005
1,154
thats very interesting as we get low to mid 20s from galaxy+indiana with bikes on back.Can borrow a roof mount for bikes and see if its better.
Nov 12, 2009
1,142
graham, i take it your car is the diesel model as you mention sixth gear ?. i did say mine was the petrol version. good advice if i was going to change to the diesel and thanks for that, but last weekend we went and traded in for a hyundai tucson, still the petrol model but a much higher towing capability. get it tomorrow and planning on being away for long weekend ( if the predicted heavy snow disny come )
should have a good comparision by then :)
