EH52ARH said:You should not have to change the settings when on either EHU or on caravan battery power. Not everyone could do the adjustments.
MrRee said:But the pressure switch is just a switch, on or off, at the same pressure point ..... this is why I don't understand the voltage explanation?
Had the van serviced today, the Engineer said that my pump is too powerful and has probably damaged the balloon in the damper????
TerryIvybridge said:I had the same problem earlier in the week, carried out a search on here and just didn't find this post? Anyway, I too find going on grid to off grid, after 2 or 3 days even using the solar panel, I have to tweak the pressure switch? Can someone say in which direction should it be turned when coming off 230v to battery power ie: anti or clockwise? I have to screw out anti clock quite a number of turns half a turn at a time?
