Water pump lunar chiron
Check the connections where it plugs in first as they tend to get corroded and make a poor connection. Use some sandpaper to clean the connections.
Worth also checking that the impeller can rotate. Usually there is a filter cap clipped on the end, remove then reach in with a tiny screwdriver and try to turn it in either direction then try again. We assume you have the ‘pump’ switch activated an the control panel and that other 12 volt lights etc work.
Looking at the photos on Google it looks to have a Truma drop in pump, later Lunars also use this system. These are widely available from caravan accessory shops.
