water pump
Sep 9, 2025
Hi, we have just purchased our first caravan, its a swift conquerer we have purchased a whale water pump but when connecting it the water is coming straight back out of a hole adjacent to the pump connector we have been told to close the valve but cant locate it. hope someone on here can help as we are novices to all this. thank you.
Mar 3, 2022
432
342
4,935
Look for a yellow flick switch set into the water pipe close to the 2ster heater tank
Sam Vimes
2,842
2,319
12,935
If you mean coming out underneath the caravan, then the drain valve for the hot water tank is still open. Which is what Mr Grumpy is referring to. Should be next to the hot water tank.
Sep 9, 2025
The first photo is where the water pump connects the second is a the back of the caravan under the bed. Can't locate a yellow lever anywhere. Help lol
Mar 3, 2022
432
342
4,935
Can only suggest you look around the area inside the van above where the water is coming out. There should be a valve there to allow the system to be drained.
4,844
If it were the Trauma, I have a outside shower connection net to the water inlet,,I don't know if Whale do the same.
