Hi all,
I have a Pageant series 5 Bailey which has a Thetford C200 CW manual flush loo. The flush is quite weak so I suspect there is a problem with the bellows. I just can't see any obvious way of getting into the workings of the unit. Any hints or tips would be most appreciated!
Gary
you will probably find that the bottom section of the pump has come adrift due to one of the 3 "legs"breaking this can be fixed with a small plastic zip lock
TD 42,
Thanks again, you were spot on. Well, nearly. Two of the clips were broken! Duly fixed with a bit of careful drilling and cable ties. Full flush restored.
Gary
