Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
We’re currently investigating an issue related to the forum theme and styling that is impacting page layout and visual formatting. The problem has been identified, and we are actively working on a resolution. There is no impact to user data or functionality, this is strictly a front-end display issue. We’ll post an update once the fix has been deployed. Thanks for your patience while we get this sorted.
Hi Lisa - can I also go to Heaven and not hell & damnation if I say to you to try "Virtual Earth". I am also a good boy - honest I wont let you down if I do go to heaven.
LMH, Another to try that I use is www.multimap.com get to the map at whatever magnification you require then click on aerial,great for checking site location and surrounding areas.
I think the site you're looking for, Lisa, is called "flashearth".
The microsoft maps on this site will give you street names and you can zoom in close enough to count your roof tiles. Only thing is some of the images are not the most up to date.
