Hi Brian i prefer the adapter kit to the Aquaroll we use it often on service pitches but you should receive a answer on here what they prefer have a nice break this weekendHi As title suggests , which is best option ?
i will be using my van for the first time this weekend it has the adapter kit but i was wondering about the whale aquasource hose?
whats your views?
Cheers,
Brian.
Presumably the Whale Aquasource hose requires recalibration?
Probably some earplugs might help with the noiseJust try a Flojet internal pump for noise. Often sited under a bed and activated at night when someone washes their hands after a loo visit.
Must dig out my old notes on how to carry out noise short inspections of marine systems. ๐
Might be a wise choiceThink my wife needs earplugs as i snore pretty bad, i blame the vodka and the stella . ๐
Well first weekend away was a hit tested and fiddled with everything on the van , I have ordered the aqua-roll valve kit but think i will also order the Whale Aquasource so i have the choice if needed.๐
We have too many unknowns to give you a clear answer because noise is a subjective issue.Morning all,
well all well first weekend away in van.
Quick question , is all waterpumps in the aqua roll a little noisy?
All water pressure in van is spot on no issues at all, i am just wondering if all pumps are a little noisy.
Cheers.
๐๐๐
If it is a Flojet pump they are quite noisy but can be quietened. Firstly they have rubber feet but the caravan maker often screws them hard into an upright surface. This effectively creates a noise short. Ideally there should be no mechanical fixing direct from pump to surface. But eh oh itโs a caravan not a submarine. Re position the pump to sit on a flat surface and the screw fixings donโt have to be so tight as when itโs vertical so the rubber supports more of the load. Also make sure pipework near to the pump doesnโt touch fixed surfaces as that too acts as a sounding board. A small bit of pipe insulation foam works well. Lastly near the outlet of the pump there is normally an cream cylinder like item that is vertically mounted. This is a simple accumulator to even out pump discharge pressure. That can resonate against its supports and create noise. Best way is run the pump and jiggle the accumulator to see if it gets quieter. Then a piece of pipe insulation foam can be inserted to reduce its vibration transmission into the support.Cheers, least i now know there is nothing wrong with it, thanks ๐
