- May 7, 2012
- 8,594
- 1,819
- 30,935
Transverse beds need to provide a semblance of access past the bottom and so are limited in length, even on an 8 ft wide caravan and even other layouts tend to limit the bed length because of overall room constraints. Very few go seriously over 6 ft. Possibly the best bet for very tall people is using the front lounge as a bed so you get the entire width of the caravan which should be 7 ft plus.
If you are looking at second hand models, there are a few still around with the double lounge layout, where you can leave the rear one made up as a bed to get near the benefit of a fixed one. there are also a few models where you can have a second lounge where a side bed would normally be which converts to a bed if needed. This would allow the front lounge to be used as a bed and you then can use the central one as the main lounge, if that would work for you.
