i tow my caravan with a ford focus 1.8 tdci but find that i need a bit more power,i would like a car that looks like a four wheel drive but not four wheel drive i.e 2.0 ltr, any ideas thanks.
If you want the higher driving position of a 4 X 4, but mostly two wheel drive, have a look at the Honda CR-V. Drives very much like a car, is fairly economical, reasonable tax band, and the 4 x 4 only kicks in when you need it
Had our CR-V 2.2 tdi for nearly a year just started towing which even in the strongest June winds was easy as it has trailer stability system as stardard on the Honda. Towing MPG 26 - 29(following wind) Solo 40 - 46 but thats with air-con turned off.
