EH52ARH said:
Wind going across the top of a slightly curved surface will give it an enormous amount of "lift" to the surface and could cause the window to be pulled out, maybe the Prof could help.
Hutch.
Hello Hutch,
Why do you think that
hmy: ?
I hadn't given much thought to this thread, but logically any window will have a burst pressure but smaller windows will need more pressure than a large one (pressure times area = thrust), so if it were simply a windage problem, then it would be more likely a larger one would go first.
You would need enough differential pressure inside to out, which would be achieved with little air movement, but whilst this might break the window seal to the body of the caravan, but as soon as the seal is broken, you would need quite a substantial mass air flow into the caravan to continue to blow the window out.
The wind would have to have reasonable free access to the inside of the caravan, Its unlikely the normal ventilation slots would provide enough open area to allow enough air mas smovement to blow out a window, so unless there was a door or another window open, it seems less likely to be the only cause.
However if the window had been previously damaged and weakened, then its conceivable windage could cause it to fail - but that is a bit of a long shot in my view, as towing could well provide enough mass air flow, and is likely to explore any weaknesses more than just the wind .
It's really not possible to be conclusive about this on a forum, and even a close inspection may not produce a conclusive outcome.
