So, yesterday with time on my hands I had a cursory check under the van to ensure all is well when I spotted an 'L' shaped bracket hanging precariously close to the ground, swinging in the breeze. It turns out its a bracket that supports the brake rod and fastenes / screws to the floor of the van on the underside.
As there isn't enough ground clearance to climb under and reattach it I need to raise the van to give me some more ground clearance so I can scramble under on my back. Having never had to climb underneath before I'm thinking that I'll chock the wheels, raise the rear corner steadies and wind up the jockey wheel to tilt it backwards. As I dont want to start using jacks does this sound a reasonable solution?
