For warranty read guaranteeMany dealers have a preprinted schedule that they give you. It is basically a series of boxes that are ticked off as the majority of the service is a 'check that it functions' deal. They do not actually remove anything for checking apart from the brake drums. Unfortunately the majority of what you are paying for, is for someone else to tell you what you probably already know, but that is the system the manufacturers and dealers have come up with to relieve you of cash.
Check what exactly your Warranty covers you for and then decide if it is worth continuing with, and if not, get a reputable independent servicing agent to do the work.
Did i read it right , empty the van before a service !!!. No chance , last time i swaped the van took me a week to empty and refill, the main quantity was put in by the wife , god knows why cos most of it never moves.Thank you Read for the sight of the schedule.
I note that the document reference points to it being produced by the AWS scheme 15 Sep 2009 and so not your own creation.
It raises a few questions - perhaps you could enlighten us as to how your company tackles these issues.
Nose weight. As most dealers recommend emptying the caravan of personal belongings prior to service, What value is there in measuring and recording the nose weight. From a technical point of view you will not know what height the towball is on the customer's car when it is loaded for towing.
Age of tyres, the general rule is now five years not Seven.
Brakes, there is the debate about drums whether to remove or not. How do your technicians check the correct operation of the brakes? Do you check the brake efficeinecy?
How do you check the charger output rate?
Glaring errors that show it was not proof read by professionals
What does the "9" refer to in the heading of the gas sections?
All self respecting gas fitters know that you do not check for leaks - you check for gas soundness!
Good luck. Don't know what you paid for your Kojak but I see Towsure have them at
