Air fryers
5,337
Are these Ninja Air fryer cheap to use because we are on a pay as go meter system
Depends on what size?
AI says wattages ranging from 1550W for smaller models like the AF100UK, up to 2470W or higher for larger dual-zone units like the Foodi MAX models.
You can easily work out the hourly rate .
Your payg meter should charge the same as the site pays
5,250
Before we got the smaller Air Fryer for the caravan, we took the Ninja Max with us, but it is large and bulky when touring which si why we got the smaller 1500w Ninja air fryer. It was on special at the time. We took that away with us plus we had a small 2 person George Foreman grill for sausages and burgers. Did not use both at the same time and never tripped the mains.
5,250
As we're vegetarians we have no interest in what they can do for meat cooking but there seem to be plenty of things that we like that we can do - chips for one :)
While there seems to be much emphasis on energy saving I'm yet to be convinced this will be significant for us. We tend to use our ovens as efficiently as possible.
I've just dug out my energy monitor so that I can have some sort of reference for when we do get one. I'll let you know the results.
They are definitely a lot cheaper to run than any oven and we have an energy "efficient" oven. Hope this will help you decide; https://www.which.co.uk/reviews/air...gy-cost-cooking-results-compared-aPpAt8D1Agy5
Sam Vimes
2,585
2,078
12,935
I've just measured them and our small oven has a max power rating of approx. 1.2Kw and the larger oven 1.8Kw. The small one takes about 20mins to come upto 200degC but from then on the thermostat cuts in and out, so its not on all the time.
The same will be true of Air Fryers presumably - once upto temperature the thermostat will cut in and out.
These are max. power figures because the oven can be used in different modes with only the top or bottom element in use.
A typical vegie pie I make will take between 20-25 mins at 200degC. Not sure how I would do that in the Air Fryer though.
Roasted veggies in the oven about 40mins.
One curious thing that strikes me about Air Fryers is that many reports say that the 'exhaust -air' can be quite hot so you need to keep them away from walls. If that's the case then thats wasted energy.
Our oven appears to be well insulated and there's little loss of heat when in use. I did have the full energy efficient reports for it but somehow they got lost.
5,250
Remember the figures quoted for air fryer i.e. wattage are maximums and the likelihood is that you will use a lot less wattage when cooking and probably for a shorter duration at a lower temperature.
Sam Vimes
2,585
2,078
12,935
I have seen that report but it doesn't meet my criteria for 'a lot cheaper'.
Of course mileage may vary but I would question some of their timings and power ratings. Apart from which you can use the conventional ovens to cook thing together that you couldn't get in an Air Fryer - Bread and Pies at the same time for instance.
9,067
When we installed our new kitchen we got rid of an old inefficient range and bought an AEG gas cooker. It is well insulated as it can fit in between units with no air gap required. The main oven is gas, the smaller one which is the main usage one is gas, with an electric element for grilling. Overall there has been a reduction in costs compared to the old range, especially with gas being significantly cheaper than electric.
Feb 13, 2024
1,310
839
1,435
You sound a bit undecided on what you want, get one from asda and if it is not for you, you will not be losing much. On the other hand if you buy a ninja 🥷 you will be severly out of pocket.
5,250
Sorry to disillusion you, but in our Ninja Max you can do both i.e. fish and chips etc at the same time. Just admit you are looking for excuses not to get one! :LOL: :LOL:
4,556
We have three Air fryers, the first one is an old Tefal, which has a rotating blade to "stir" food whilst it cooks things, chips, veg even soups it says, really noisy and only one temp. Hardly ever use that now.
2nd one from Lidl, about 2 years old, smallish basket 5 litres, very versatile.
3rd one, also from Lidl, a triple shelf with rotisserie, never tried that bit. Max temp 200c much more like a small fan oven.
5,250
We have previously had appliances with rotisserie and once you have used one, you will never use it again! LOL! :LOL:
Sam Vimes
2,585
2,078
12,935
To be honest your right - its one of those things that for quite a long while we've thought yes - no - yes - no and now its yes but I still have reservations. Many people think they're great but to use an appropriate metaphor - the proof is in the pudding. :)
5,250
Only you can eat that pudding and then make a decision whether it is good or bad! :LOL:
