Berker 12 volt Cigar Socket and Satellite Point Anthracite W4 Caravan 21229A
Hi, Anyone on here got a second hand one of these. Looking for one to convert socket to RJ45 socket.
UPDATE:
Using the idea that GUMPY suggested, I have built my panel requites, installed and just need to test system out.
So big THANKS for everyone's input.
Good Question, and a simple answer, As i have no other available positions i wish to convert the current TV/SAT sockets to the SAT/12v socket and convert it. I still need the TV socket and i prefer to use the screw fixing to connect a tv ariel. I see your point of view. i have blanks, i have F connectors, i have hole saws, just wanted a easy option but a very good point, cost me nothing then,
The Belling-Lee (i.e. TV) aerial socket is just a panel mounted F-type adapter. All you need is a F-type outlet bulkhead jack-jack i.e that has a F-type socket on both ends and replace the existing.
The Belling-Lee (i.e. TV) aerial socket is just a panel mounted F-type adapter. All you need is a F-type outlet bulkhead jack-jack i.e that has a F-type socket on both ends and replace the existing.Thanks for your responce. I an running eithernet cables
Hi, thanks for the reply.Yes, I have the F‑connectors.
My project is: I am running Ethernet in the caravan, and I need to fit an RJ45 panel‑mount socket as well.
The reason I asked for thehttps://forums.practicalcaravan.com/attachments/s-l1600-1-webp.10432/?_gl=119vvw53_upMQ.._gaMTU2MTMwODYwNC4xNzc2NTE0ODkx_ga_1JCMYRPXYF*czE3NzY1MTQ4ODgkbzEkZzAkdDE3NzY1MTQ4ODgkajYwJGwwJGgw was to knock out the 12v socket and fit my RJ45 socket, as I have done with two previous 12v sockets, to great success.
But where this final cable is going, I do not have free spaces, hence I was going to use the aforementioned socket. However, having had input from GUMPY, I’m going to attempt the conversion of a blank plate.
I have to ask:
Why?
I am a great believer in cable connections and run everything possible over Ethernet at home to get maximum bandwidth and speed.
However:
Everything in our van is on 5ghz WiFi which is always faster than my 4g/5g internet connection. I did come close once with a 500mbps 5g connection😉
Why Not! Cable is much better. simple.
If you only have one thing to connect.
Otherwise it means adding a network switch and network adapters for things like Firesticks and Roku. Which adds complication.
Says the man with 4 network switches in his house and two Roku plus a fire stick all with adapters on them.
Gumpy beat me to it - I was going to ask the same question! After all inside a caravan you will have a saturation wifi signal, and to some extent it will be screened from other people by the Faraday Cage effect of the caravan body.
What is more if you have a cabled system then you will probably need a switch or router either or both of which eat electricity (relative) whereas a mifi unit can be fed by a micro USB cable and draws no more than 1-2W at most.
If you get a Huawei mifi that has TS9 connections you can buy a single or couple of external aerials that plug straight in and improve the signal OR you can put a small cellular aerial outside and feed it to the mifi maybe just inside a skylight (the one nearest the kitchen or in the bathroom usually don't completely seal) to allow you to get the very thin cable through the gap.
The router i have for caravan is a 4 port router. We have two tv's and my business laptop. No need for a switch at moment.
I doubt many caravans come close to being a Faraday Cage. If they were we wouldn't be able to receive our WiFi from external sources nor 4g/5g mobile signals without some wired feed into the caravan.
Also interesting to note that many new devices don't include wired ethernet connections and WiFi is the method.
Any of my stuff at home that can't have a wired ethernet connection sits on a dedicated 2.4ghz WiFi system away from other stuff on 5ghz.
Anything that works with a USB Ethernet connection gets fitted with one.
There are things that don't accept it like garage door opener, Octopus Mini, printer, immersion and my solar inverter, these stay on WiFi.
