Bulkhead gas regulator replacement
Jun 16, 2023
89
33
585
Hi All,
Is it something that should be done by a certified gas engineer or is it ok to do it yourself assuming you are confident in your skills?
Nov 30, 2022
1,577
1,437
2,935
It's a pretty simple thing to do, but you need to be sure there are no leaks once you have done it.
Me? I would happily do it (and have done in the past) But I did/would check carefully fir any leaks.
To all the nay-sayers who will tell you tge world will end if you do I will just ask them what's the difference between replacing a regulator, and changing your gas cylinder? Or for that matter replacing your pigtail? Both require gas tight joints
4,612
Fully agree. If you are intelligent do it.
I carry an aerosol can of gas leak detection spray. Use this to check your new joints with the gas flowing.
Crossed with Hutch馃槈
Jun 6, 2006
833
153
18,935
It鈥檚 also wise to change the pigtail if your are changing the regulator due to oiling as it got to the regulator via the pigtail 馃
