Bulkhead gas regulator replacement
Hi All,
Is it something that should be done by a certified gas engineer or is it ok to do it yourself assuming you are confident in your skills?
It's a pretty simple thing to do, but you need to be sure there are no leaks once you have done it.
Me? I would happily do it (and have done in the past) But I did/would check carefully fir any leaks.
To all the nay-sayers who will tell you tge world will end if you do I will just ask them what's the difference between replacing a regulator, and changing your gas cylinder? Or for that matter replacing your pigtail? Both require gas tight joints
Fully agree. If you are intelligent do it.
I carry an aerosol can of gas leak detection spray. Use this to check your new joints with the gas flowing.
Crossed with Hutch😉
It’s also wise to change the pigtail if your are changing the regulator due to oiling as it got to the regulator via the pigtail 🤔
