- Jul 18, 2017
- 15,754
- 4,938
- 50,935
Why take it to any dealer when an independent will probably do a better and more honest job?it just a pity i cannot take it to another dealer and get a second opinion on it . but my new car should be here asap
Try Quick Fit , they do brake inspections,it just a pity i cannot take it to another dealer and get a second opinion on it . but my new car should be here asap
However whatever you do never ever let Kwik Fit touch your vehicle as the bill be higher than the dealer. We unfortunately learnt the very hard way.Try Quick Fit , they do brake inspections,
Adaption Chesterfield will contact when they need my Pride rapid mobility scooter and some extras to be fitted but still waiting for the new car to come at Ford dealershipBB how long will it take for all the disability equipment to be fitted? Not another three months I hope😢😢
But surely your brakes aren't at such stage that they are dangerous are they. A week isn't really going to make any difference to the wear or corrosion. How about Protyre, ATS, National etc or Halfords which is where my daughters 2022 NHS Toyota lease car has to be serviced.To answer Hutch and Buckman the nearest brake check is Kwik fit and like you (Buckman) i had a bad experience with them i have contact the garage my wife uses he cannot look at for over a week he busy with service and MOT so with this in mind i will let my car dealer sort it as arranged
Sounds like a further long wait!Adaption Chesterfield will contact when they need my Pride rapid mobility scooter and some extras to be fitted but still waiting for the new car to come at Ford dealership
I think you are in abuse of the forums rules, towards Kwick fit , my local one is very good.However whatever you do never ever let Kwik Fit touch your vehicle as the bill be higher than the dealer. We unfortunately learnt the very hard way.
Interesting. Down here they are know as Kwik ##it😵💫.That’s the problem with National chains .Only as good as the guys who run the branchI think you are in abuse of the forums rules, towards Kwick fit , my local one is very good.
Hi clive Rear brake disc and pads for replacement the front brakes are okay but i would rather be safe for road safetyBut surely your brakes aren't at such stage that they are dangerous are they. A week isn't really going to make any difference to the wear or corrosion. How about Protyre, ATS, National etc or Halfords which is where my daughters 2022 NHS Toyota lease car has to be serviced.
BB I doubt for one minute your brakes are unsafe. If they had been the Dealer would not have allowed you to remove the car!Hi clive Rear brake disc and pads for replacement the front brakes are okay but i would rather be safe for road safety
I can understand that you want to be safe but nowhere have you given any information as to what the disc thickness is, or what the remaining pad dimensions are. Our dealer and tyre fitters always give a paper print out of such things. Wrt safety your front ones do most of the braking work especially when unloaded.Hi clive Rear brake disc and pads for replacement the front brakes are okay but i would rather be safe for road safety
Not this time my car is nearly five years oldAre we talking a mobility car here Beachball?
Here’s BBS brake disc. Looks ok to me😉Not this time my car is nearly five years old
My car is in to the dealer on Tuesday as we have a strong smell of diesel coming from the engine bay. Its still under warranty but they always give the car a 'health check'. It'll be interesting to see what else they come up with, which shouldn't be anything.
May have been cheaper to have taken the caravan and stay overnight if you had known😁The car went into the dealer yesterday and highlights the joys of living in a reasonably remote rural location. For this type of investigation and work they go on a first come, first served basis, so we set off at 6am to get there for 9am. Even then they didn't start until 2pm.
The problem is a fractured fuel feed to the injectors. A small amount of diesel was dripping onto the engine and they declared it unsafe to drive - we'd been driving around like this for about 2 weeks! They can't get the part until tomorrow, so we had to get a bus home. So having started out at 6am we arrived back home at 9.30pm
No courtesy cars available, although I did suggest they give us one of the new shiny ones in the showroom
While there we asked for the rear passenger door to be looked at since it doesn't always open from the inside. Of course it worked for them and because of that they were dubious that it could be fixed under warranty. However, they checked and the 'powers that be' said yes both problems were covered.
They offered to look into getting one of their drivers to return the car to us but I'd rather collect it because I know where all the pot holes are on the way home. So another early start tomorrow and bus to Inverness.
No other problems came to light. Always had good service from the dealer but only use them when things need doing under warranty or are a bit more complex than our local garage can cover - which fortunately isn't often.
