Caravan Cleaning
Jan 4, 2008
18
I am having difficulty in cleaning the white pastic areas of my caravan no matter how hard I try it still looks dirty and tarnished, can anyone offer some advice on this.
Feb 28, 2009
493
Hi Peter,
If you are referring to the battery locker doors etc. I found that once they started to get tarnished Cif seemed to work quite well using a green soft scouring pad. They did seem to get dirty quickly again though.
Jim
Jan 19, 2002
1,706
547
Try a quality cleaner like MER for both washing when diluted in water and neat for polishing. Personally I would avoid household cleaners or using anything that has an abrasive surface.
Dec 23, 2006
788
Peter,
On the white plastic parts of the caravan, if they get really dirty when out in winter, i have always used neat Fenwicks Caravan Cleaner and washed off with plenty of water.
Hamer
Aug 4, 2004
4,343
When the mastic starts to get blackened in areas, how do you clean mastic short of replacing it which is not an option.
Jun 11, 2012
1,533
33
19,685
Hay Guys please dont think Im taking the mick here as I have just used two cleaners here that seem to work well,
One is a shampoo from Asda at 75 pence a litre bottle , and of course this new Caravan cleaner from Aldi works very well
cleaned the mastic etc and black strteaks ,also used it on our conservatory to cleanblack streaks on upvc
If you go to Aldi to get that one get the concentrate .
Forgot to add the shampoo form Asda is a car shampoo
Good Luck. Sir Roger
May 19, 2008
40
Just tried the Asda shampoo this week. For me, it wasn't anywhere near as good as Fenwicks or TripleWax car shampoo. It left both the car and caravan very streaky and I had to wash them down again with Triplewax.
Oct 2, 2005
Hi Peter
Having just purchased a Rapido pop top which hasn't been cleaned since Queen Victoria was in reign, I can strongly recommend Everbuilds PVCu Solvent Cleaner. It is 'very' strong and should only be used on plastic surfaces.
It cuts through the oldest blackest grime you can imagine. Cost
Aug 23, 2009
3,167
Auto Glym caravan and motor home cleaner works very well all over with very little effort.
