So lets see if i have picked this up correctly, i need to get a broom stick, some scales. I need to hook the caravan up to the car and find somewhere level, then cut the stick to the height of the hitch (when hooked up to the car) so i am calculating the weight correctly, then i unhitch the caravan from the car and gently lower the hitch with the wood onto the scales with another piece to spread the load so can get a good reading, it cant be any lighter then minium weight 24kg.
I think i will be to the limit of 54kg by the time i have two gas bottles at the front plus bedding underneath the front seats and also two peddel bikes in the caravan.
As an estimate i recon the two gas bottles will weigh around 12kg+ plus say bedding of 2-3kgs plus two bikes so ill be getting close to the nose weight of the car.
When i have been away in the caravan previously i have put all heavy stuff, awning and wheel clamp and bottles on the axel so the noise weight isnt too heavy. Am i doing this correctly?? Im still new to loading a caravan and still new to caravaning in general.
Most of the food and other accessories we take for our holiday we would put in the car so i am sure i should be ok!
