- Jul 18, 2017
- 16,231
- 5,168
- 50,935
In a modern car, it is safe or even wise to charge the battery with it still connected? The battery is under the driver's seat so not easy to remove however there are connection points for the battery under the bonnet. Also the Jeep has two batteries in the same compartment and they are inter connected, one being the normal size stop start 12v 70AH battery and the other a much smaller stop start 12v 14ah battery. Both are AGM, I think the smaller one aids the Stop Start? On switch on the battery reading is about 12v.
Car starts okay, but does some weird things at times which is an indication that there may be an issue with the battery. The current normal size battery is a Bosch S5 A08 70AH battery CCA 760A. When doing a search for a battery all the batteries that are suitable show as being 80AH with 800 CCA?
The Jeep is only 6 years old and I have had it for 18 months so it seems unlikely that the AGM battery would have been changed prior to my purchase, but I cannot see a date of manufacture due to the battery being difficult to access.
