- Jun 9, 2019
- 3
- 0
- 0
I am completely re-wiring my Abi Monza 1991 Caravan after coming across the below that was running the 240v as well as the rats nest of connection that was taped to the gas line :blink:
I am completely re wiring both 12v and 240v as I can't trust what is currently installed, I am also removing the water heater and gas.
We don't have a shower in the caravan and the previous owner said they didn't use the water heater and to fair we would only use caravan sites with shower facilities etc.
The gas would go and I would do all the cooking on a portable stove in the awning
I'm a planning on removing the current Electrolux RM 212F Fridge as I would never use this on gas or 12V. Can I install a standard fridge? It is most likely to be a fridge with no freezer compartment, and with a bit of slight persuasion i could get 1 to fit.
I also removing the wiring for the towing lights as I don't need this to charge the caravan battery as I'm installing a solar panel that would keep this topped up.
The towing lights would just go from the car to the lights as if i was using a towing board, the question is what size cable do i use? Is know I will need 7 core do I use 11 amp cable? I'm changing the lights to led.
Thanks for your advise
 Facebook
Facebook Twitter
Twitter
