I use a reel and find the coils make rewinding easy.
This is what I do, but mines bunged in on a reel. Is winding around elbow and hand any quicker? Certainly not as tidy.Binned mine years ago, bung the cable in the front locker, job done.
We always use electric pitches so it was coming out upon arrival, so it seemed a needless faff winding it up to unwind it again.
Also not as clean if cable is over muddy areas or recently cut grass.This is what I do, but mines bunged in on a reel. Is winding around elbow and hand any quicker? Certainly not as tidy.
Spot on Prof, all sailors work their ropes that wayThere are certain professions and activities where managing considerable lengths of cable or rope is a daily task, and they have evolved some tricks which allow them to quickly coil a length in such a way that it can be unravelled by holding one end and throwing the coil away from them, without it knotting, snagging or twisting. I've done it many times on PA jobs, including EHU power cables.
There is a knack to it and you have to hold the correct end otherwise you get a knot for each two loops of the coil when its thrown out. The cable must be payed out starting with the end that was last coiled.
The method has been described previously, but essentially the winding up loop after loop on a hand and elbow, would normally twist the wire, but trick is to reverse every second loop.
As second way of doing it is to make a stack of figures of 8. Lift the cable where the cables cross.
Using a proper cable winder as those shown above, is fine provided the cable is wound up using the reels handle. and unwound from the reel. If you hold teh centre of the reel and use your other hand to pull the loose cable and wind it over, you'll have the same problems as using a hand an elbow
I have two hookup cables. One full 25m, and one that I cut into 1/3 and 2/3 sections. For CMCC sites, I use whichever gets me to the post with least slack. For CLs I have the option of nearly 50m if hookup reach. All are wrapped and held with double sided Velcro strips.The CAMH would not recommend that, although I see the idea could work, as I often have masses of cable just laying there on many sites. The plugs may not be totally waterproof and could short in very wet weather, so something might need to be done to protect the junction.
Similar colour to the Sainsbury bags that I used to duct tape up 😂It is very important to understand the difference bet weather proof and waterproof connections..Below is an example on a water proof container for the plug and socket.
Loads of similar types available on line.
🤣🤣Similar colour to the Sainsbury bags that I used to duct tape up 😂
Good post Prof. The IP are I think more for submersible applications. The example I pictured says it is waterproof but no IP grading. But better than nothing or maybe not as good as the good old carrier bag😜
