Parksy said:
There seems to be a great emphasis on checking nose weight for some reason and although I wouldn't condone exceeding stated limits for your outfit, of much more importance from a safety aspect is overall weight and correct loading of caravans.
Too little nose weight can have and adverse effect on caravan stability but none of the methods described to measure noseweight here or anywhere else can be guaranteed to be accurate, including bits of wood and bathroom scales which are notoriously inaccurate to start with.
My guess is that the Reich version would be the best of a bad bunch but as the Prof pointed out, noseweight is not static when a caravan is moving along a road surface, it can and does vary greatly due to the relative angles of the hitch / A frame and the towbar/ towball so the best that we can achieve is a mean average.
I have yet to discover any evidence whatsoever of a successful prosecution based on caravan noseweight so to my mind a quick lift of the hitch is as good a method as anything, at least if you can lift it the chances are that you won't exceed it by any significant amount.
Caravan weight is sometimes checked at the roadside by VOSA but they don't check noseweight. How many caravanners does anybody ever see checking their noseweight before hitching up after a break to head home? π
Hello Parksy,
I dont normally dispute postings with you, but your post is wrong in a number of ways.
Nose weight is determined by the way the caravan is loaded. Arguably it is more important to safety and stability than the overall weight of the trailer. I agree that too little nose weight is bad, but from a safety point of view it is equally bad (and illegal) to exceed the nose load limit of the combination. In doing so the magnification of the nose load due to accelerations induced by towing might exceed the hitches safety margins. All nose load measurements are taken statically so it eliminates any dynamic errors.
You say you don't condone exceeding stated limits, but unless you know how to measure the loads how do you know if you within limits? Lifting by hand is not a quality or quantifiable measurement system.
None of the retail measurements systems can offer meaningful calibration of nose weight measurement because unless they allow you to take the measurement at the hitches towing height the measurement will be inaccurate. The Reich device raises the hitch, and that means it is not actually measuring the nose load, and it cannot include any means to compensate accurately for the change in height.
All Gauges have inaccuracies, but bathroom scales will be more accurate than the compressive spring loaded nose load gauges available to caravanners.
The DVSA (Formerly VOSA) can check nose weights, it is within their remit and if exceeded they could (through the police) prosecute.
All I have done is to explain how to measure nose load correctly, in a way that conforms with the law and that will reduce errors and overloading. So why not encourage caravanners to do it correctly, and point out the errors and dangers of doing it incorrectly?
Oh and I used to check on every journey, and I have seen a few others doing on site before leaving but the majority don't.
