Ford Mondeo 2 litre TDCI Hatch back. 2011 nose weight
Jan 15, 2011
570
8
Hello all. I am sure this question is one of the old chestnuts that keep coming up so I apologise for raising it again.
I am thinking of upgrading from a Ford Focus to a Mondeo the 2 litre TDCI. Hatchback (manual)
When I put my proposed details into the what tow car match site it tells me that the nose weight allowance for the mondeo is 75 kg.
I have checked with the ford website but the only cars they display technical details for are the current 2013 models and this states the mondeo nose weight limits to be 90kg.
I have also checked a couple of ford dealerships and they both say that the current models have not changed apart from cosmetically since the end of 2008 so the current spec of 90kg should apply to all after that time.
The should apply worries me somewhat I did expect them to quote me from some official document.
Well that all sounds ok to me but before I dive in at the deep end I would like to see some official confirmation.
I know the what tow car site is not guaranteed to be accurate and should only be used as a guide site. I am wondering if anyone can point me to a list where I can get an accurate and official idea of a 2011 Mondeo 2litreTDCI Tow hitch loading.
If it is only 75kg I am going to think again.
Regards to all
Brian
2,640
Hello Brain,
I'm sorry but I don't follow your reasoning. I don't know what your Focus' nose weight allowance is but I suspect it will be only about 75kg. So if the Mondeo is only 75kg you are no worse off in that respect, but you will will probably have a better tow car.
Even if the focus is 90kg and the Mondeo is 75kg, I still don't see that as a problem. Yes you are advised to keep the nose weight close to the available limits, but in reality there will be plenty of people who tow a Baily Ranger GT60 460/2 with a car with 75kg NW limit.
You only need to use as enough nose weight to keep the outfit comfortable to tow and it might open up your choice of towcar.
Whilst excess nose weight (provided its within the car and caravans limits) is not a bad thing but its not actually necessary.
Jan 15, 2011
570
8
Hello Prof thank you off the reply. Yes I understand all the points you are making and perhaps my question was a bit long winded, what I was mainly trying to determine is what is the nose weight limit on Ford mondeo diesel cars after say 2010.
because the two main dealers who I have contacted think that because because Ford state the nose weight limit for the 2013 models is 90kg. then older ones should be the same. They are unable to point to anywhere I can get an official figure.
The nose weight of my current focus is 75kg and I do struggle to get the caravan to that figure it works out at 75 with only the one lightweight gas bottle in the front and of course the mover adds to the equation. I tend to carry most things in the car and always (now) remove the jockey wheel into the car after hitching up. I have one of the gauges for measuring but have also used the bathroom scales on level ground with the van as level as possible.
my thoughts regarding the mondeo were if the nose weight of those was 90kg then I perhaps wouldn't have to worry to much if I was over the 75kg mark by a couple of kgs. Also the Size of the mondeo would widen my options when considering any other van in the future.
Thank you again for your reply regards Brian
Oct 30, 2009
1,546
hi Brian,
75kg is a heafty weight (about the same as the average adult). and also about the average noseweight for a van, you say you stuggle to get it down to that but it is really down to loading. I could suggest that some of the things you carry in the car should actually be in the van as a counter weight, my van has a empty nosweight of 103 kg but I have to get it down to 45kg for the car, (max 50kg) and is done quite easily by carrying heavy items on the floor of the van, moved futher back and the spare wheel just inside the door, instead of in the front locker "proper place in the bailey" I honestly dont see why you need to have it to 90kg, if you think about it the difference is only 15kg or in other words 7.5kg behind the axel instead of in front. it will tow just as good at 75kg as it would at 90kg.
Oct 30, 2009
1,546
hi again, I don't suppose this helps much
but I have had 2 mondeo's both have been 75kg one saloon, one estaste, but neither were the current model, as the floor plan has not been changed though I would assume it is safer to go with that,
Jan 15, 2011
570
8
Thank you for the reply Colin. Perhaps I am making to much of the nose weight issue. I do always check before each journey and the load is usually around 75kg.
My Spare wheel is under the van behind the axle. I have always tried to avoid larger or heavy items in the van but thinking about what you say and the Prof in the previous reply just by putting my Awning on the floor slightly to the rear of the axle would probably reduce my nose weight. I understand that a healthy nose load helps with the stability but always have concerns about exceeding the limits of the car.
my thoughts regarding a tow vehicle with a greater capacity were that I would always be well within the tow vehicles limits.
My main point is that I have from the two enquiries I have made to Ford dealerships been unable to get a concrete answer as to the actual nose weight limits of the Mondeo. And the What Tow Car Site says all mondeos are 75kg even 2013 models when Fords site says that all their current models are 90kg.
thank you for the reply Colin
regards Brian
2,640
Hello again Brian,
Just some further thoughts for you.
Lets start with construction and use regulations, The EU regulations require the tow ball to handle at leas 4% of the maximum towed weight,and certainly those I have checked do conform to that or give a bit more.
Alternatively, The EU regulations aslo require the tob has a data plate fitteed that includes the maxium nose load limit. Ask any of the towbar manufacturers/dealers and they should be able to tell you.
Alternatively, if you see another car of teh model your interested in, ask if you can check the data plate.
Aug 11, 2010
1,382
high brian.. this magazine PC, QUOTED the 2.0l 163tdci est as 80kg in 2010 the facelift 2011 was qouted at 90kg....towsure quote their
towball at 80kg... i would suggest that 80kg would be OK given the sources i have seen....
Jan 15, 2011
570
8
Thank you for that JonnyG.
i find it strange that Two Ford dealers were unable to tell me the nose load figures. In fact something happened on Thursday that must be a first in the second hand car world and that was where a salesman Didn't ring me back after my enquiry I spotted a Mondeo in my price range and rang the dealer to see if it was still actually available, with it being about 25 miles from home. He said he would get back to me after checking stock, however I also asked if he could find out the max tow ball loading for that model and he said no problem and would get back with that info also.
Still not heard a word. My usuall experience of salesmen is that they ring ASAP. After an enquiry and then at least once a week with all the other offers they have.
like the other posters have pointed out, a lower nose limit is achievable to suit a particular cars limits with correct loading so I don't have any real difficult issues either way but would like to see some official figure for any car I was buying.
thanks again for the reply.
regards Brian
I think one has to realize, that in the normal car salesmans world, nose weights are a alien question, They are not mentioned in the Ford Mondeo Handbook , My last cars handbook, gave the max nose weight along with max tow weight of a braked trailer, this is not mentioned what Fords do say in My logbook is a set of figures listed as follows Gross vehicle weight 2170Kg, Gross train weight 3970 Kg,Maximum front axle weight 1140 Kg, maximum rear axle weight 1075 Kg.You have to talk to the Technical people for positive results.
The figures above take the gross vehicle weight, from the Gross train weight gives the max towing braked trailer weight.
My question to the experts is when a towball plus electrics is added to the chassis , This must have have a effect on the Gross vehicle , and Gross Train weight figures mentioned above.
Royston
2,640
Royston
The addition of any extras (such a tow bar etc) to the car has absolutely no effect on the vehicles GVW or the GTW, Those are fixed figures. What the extras do is eat into the vehicles load capacity. So if a tow bar assembly weighs 15kg, then you have 15kg less load capacity.
5,296
The early model Mondeos of the current shape had a lower noseweight ( from memory 75 or 80kg) but this was increased to 90kg quite early in the models life. Whatever the current shape Mondeo won numerous towcar awards (TOTY) when it first came out so even with the lower (slightly) noseweight it will be a good towcar. The difference between 75 and 90kg is almost academic. When I had a Mondeo there was a Ford Technical Helpline number in the Owneers Manual, which if you rang them put you through to someone who knew what they were talking about. But you did require the cars details such as Regd Number as a minimum. My XC70 has a n-w of 90kg but i tend to load it to between 75-80kg and she's dead steady, but the car gets the heavy items and the van gear is stowed low down and around the axle.
chenzhen
BANNED
May 19, 2016
99
"The word vintage, used to describe dresses and clothing, is a broad term that is generally used to refer to clothing that originates from a past era. In general, clothing that dates earlier than the 1920s, is considered to be antique. Whereas clothing and dresses that have emerged after the 1920s, up to the 1980s and 90s, is considered to be vintage. Retro, or vintage style, usually refers to clothing that is an imitation of the style of a previous era.
A range of vintage style clothing that is hugely popular today, are the fifties dresses. The enduring popularity of these dresses, might be because that was the time women's clothing made significant strides, as it was after the second World War and many restrictions had been lifted and designers had more freedom and materials available to create beautiful women's fashion ranges.
Some of the popular dress styles that have enjoyed a timeless appeal have included the Ophelia dress, floral tea dresses, Audrey Hepburn style dresses, the figure hugging Lindy Bop dresses and dresses made famous by Grace Kelly and many classic Hollywood stars. Even today, young women are choosing vintage style dresses for their special occasions such as a ball, prom night, and other formal parties, because they have a definite charm and elegance and have been designed to enhance a woman's shape and beauty."
fake oakleys
michael kors uk
cheap ray bans
rolex watches for sale
nike free flyknit 5.0
ugg boots
coach outlet online
yeezy boost 350 white
michael kors bags
air max 90 white
ralph lauren outlet
louis vuitton bags
converse sale
coach factory outlet
adidas shoes
nike free flyknit 3.0
burberry outlet
nike air force
cheap ray-ban sunglasses outlet
tory burch shoes
nike tn pas cher
chaussure louboutin
adidas nmd runner
louis vuitton handbags
skechers outlet
oakley sunglasses cheap
cheap jordan shoes
ray bans
adidas nmd black
reebok classic
adidas trainers
vans store
nike cortez white
pandora charms
air max 90
adidas shoes
fitflops shoes
timberland uk
pandora charms uk
armani exchange
burberry bags
under armour
louis vuitton outlet stores
oakley sunglasses wholesale
pandora jewelry outlet
cheap basketball shoes
ferragamo
ralph lauren
pandora rings
toms outlet
michael kors outlet online
prada sunglasses wholesale
cheap ray bans
www.coachfactory.com
cheap air jordans
michael kors handbags
valentino
michael kors outlet clearance
michael kors outlet
ugg boots
ralph lauren
ghd
mizuno running shoes
nike air force black
cheap jordans
nike free run flyknit
cheap ray bans
sac longchamp
kate spade outlet
cheap ray ban outlet
ray bans
true religion jeans
babyliss hair dryer
michael kors bags
true religion outlet
reebok outlet store
ray bans
nike trainers
polo outlet
fitflops
adidas superstars
true religion outlet store
kate spade uk
discount nike air max
ray ban sunglasses outlet
jordan pas cher
levis 511
nike huarache
omega speedmaster
christian louboutin uk
michael kors outlet store
tiffany jewelry outlet
polo ralph lauren men
adidas supercolor pink
rolex replica watches
ray ban outlet store online
cheap nike air max
coach outlet store online clearances
tory burch flats
hollister hoodies
nike cortez shoes
louis vuitton outlet online
hollister hoodies
pandora jewelry
louboutin outlet
coach factory outlet online
adidas pure boost black
designer handbags wholesale
yeezy boost 750
true religion
kate spade outlet online
tiffany uk
lebron james shoes 12
red bottoms outlet online
cheap jordan shoes
jordans
gucci borse
gucci handbags outlet
ray ban sunglasses sale
lacoste shoes
bottega veneta shoes
michale kors uk
ray ban sunglasses discount
louis vuitton uk
cheap ray ban sunglasses
longchamp outlet
micahel kors
adidas superstar white
air max
cheap nfl jerseys
burberry outlet
christian louboutin outlet
hollister clothing store
oakley sunglasses outlet
ralph lauren
nike blazer
michael kors canada
birkenstock sale
cheap ray bans
white converse
louboutin pas cher
jimmy choo
ed hardy uk
bottega veneta sale
north face outlet
nike air max 95
burberry sale
abercrombie and fitch outlet
hollister kids
louis vuitton purse
supra outlet
nike huarache black
nmd adidas
asics running shoes
lacoste polo shirts
jordan shoes
michael kors canada
abercrombie & fitch
coach outlet online
tiffany jewelry
burberry outlet canada
ray ban sunglass,ray ban sunglasses,ray ban outlet,cheap ray bans,cheap ray ban sunglasses,cheap ray bans,ray bans
ralph lauren outlet online
canada goose outlet
mlb jerseys wholesale
vans outlet store
birkenstock sale
coach purses on sale
ferragamo outlet
valentino bags
rolex submariner
mont blanc outlet
hollister co
nike air force
the north face outlet
armani outlet
tiffany and co outlet
michael kors handbgas
cheap oakleys
north face jackets
dior sunglasses 2016
coach outlet online
north face uk
kate spade bags
polo ralph lauren outlet
ray ban outlet online
adidas nmd uk
ghd hair dryer
jordan shoes
hollister uk
michael kors uk
buy red bottoms
nike roshe run
kate spade outlet
toms shoes
cheap oakleys
louis vuitton factory outlet
polo ralph lauren outlet online
puma outlet
true religion uk
chi flat iron
fitflops sale clearance
true religion jeans outlet
michael kors outlet canada
michael kors outlet
oakley sunglasses
instyler max
true religion jeans
fitflops
fitflops shoes
polo ralph lauren
pandora sale
michael kors outlet stores
hermes outlet
cheap oakley sunglasses
nhl jerseys wholesale
toms outlet
longchamp uk
timberland shoes
asics gel kayano
michael kors outlet
ed hardy
polo ralph lauren
versace sunglasses wholesale
louis vuitton borse
kate spade handbags
new balance shoes
versace sunglasses
birkenstock outlet
oakley sunglasses,oakley sunglass,cheap oakley sunglasses,oakley sunglasses cheap,oakley sunglasses outlet,oakley store,oakley outlet,oakley outlet store,oakley sunglasses sale,oakley sunglasses discount
michael kors bags
birkenstocks
nike air max 90
timberland boots for men
kobe bryant shoes
adidas shoes
birkenstock shoes
christian louboutin shoes
under armour outlet store
rolex daytona
michael kors outlet
abercrombie outlet
birkenstock uk
cartier
omega
polo ralph lauren
true religion sale
burberry outlet stores
nike shoes for cheap
nike store uk
sac longchamp pliage
nike force 1
ecco outlet
coach outlet online
louboutin shoes
canada goose jackets
nike free runs
reebok
converse outlet
coach outlet online
stephen curry basketball shoes
hollister kids
jimmy choo outlet store
nike air max 90
hermes belt
louboutin shoes
supra store
stan smith adidas
toms outlet
rolex watches uk
wholesale nike shoes
gucci outlet online
yeezy boost 350
nike free 5.0
cheap nfl jerseys
reebok shoes
coach outlet online
coach outlet store
tiffany and co jewelry
timberland shoes
ray ban outlet
timberland boots on sale
cartier love ring
white converse
louis vuitton purse
air max 90
ralph lauren pas cher
air jordan shoes
prada handbags
michael kors canada
holliste sale
adidas gazelle
nike flyknit racer
oakley sunglasses uk
yeezy boost 350 balck
lebron james shoes 2016
ralph lauren outlet
nike running shoes
kobe 11
nba jerseys wholesale
coach outlet store
michael kors handbags outlet
hollister clothing
louis vuitton pas cher
ralph lauren sale clearance
cheap oakley sunglasses outlet
"One of the most popular, but simple fifties dresses, is the petticoat. This was designed to be flattering to a lady's shape and also, to enhance the dress she was wearing over it. Petticoats made of silk and woollen materials were initially introduced for women to wear under the main dress, as they provided warmth and would enhance women's busts. The classic petticoat then became shorter and lacy petticoats became the fashion, as they delicately accentuated the dresses that were worn over them, such as the Ophelia dress.
Vintage style dresses UK are available in a wide variety of sizes from vintage clothing shops, textile fairs, auctions, flea markets, estate sales, antique markets, garage sales and collectable fairs. However, there is always the risk with buying genuine vintage clothing, that the sizes may not match current clothing sizes. But there are a number of special boutiques online, who specialise in designing and creating vintage clothing to order. They can take your specific measurements and produce an outfit that will be tailor made and fit you perfectly"
DHD
