gas butane///propane
5,264
My last three caravans gas locker could take two cylinders , either 6 kg propane or 7 kg butane.
Whilst the bases of these and the smaller ones may be the same I am not certain the retaining straps are mounted low enough to firmly secure the “dumpy “ cylinders in transit. My straps may struggle and may need serious remounting to accommodate the smaller cylinders
Reactions: BurningSmell
4,497
I tend to strap down my gas cylinders with the straps going around the Neck of the cylinder, there for holding them down into the plastic base.,
5,182
Is Patio gas the same thing as Butane gas as they probably both us the same connectors?
8,968
Thanks, but does it use the same connector as a propane bottle or is a clip on like for a Butane bottle.
Mine is a vertically pushed down clip on regulator. Once connected the lever is turned through 90 degrees to open the gas flow. To shut down, turn lever through 90 degrees back to the horizontal, then press release catch which is just under the lever. Mine is like the one in the link below but without the pressure gauge as the cylinder has a gauge, but still better to swing the cylinder to gauge contents. 😂
5,182
I have a spare butane clip on connector which operates as you have described which I am hoping I can use on a Patio gas bottle. (y) (y)
4,497
Patio gas uses a 27mm clip on connector,
A butane uses a 21mm clip on.
Just Google search for them
4,296
As Hutch has identified, the patio gas connector and the clip on Butane connector are not the same. They may well use similar designs, but for compliance with UK gas regs, they are different sizes, so you should not be able to mix them up.
5,182
Collect a Calor 13kg patio gas cylinder earlier today and a refill is now £54! When we last refilled our 13kg Butane bottle the cost was under £30. I know it is different gas, but a huge jump in price! Back in 2007 we could refill a 45kg Propane bottle for about £45!
8,968
Good job you don’t use Camping Gaz cylinders as a Black Horse loan would be required.
Sam Vimes
2,520
2,023
12,935
By coincidence we got a 19kg propane today for use at home. Flogas at £56 delivered which has been the same price for the last two years.
