- Jun 13, 2007
- 85
- 0
- 0
My biggest issue is my road lights. After cleaning up the plug as Damien suggested they were no better, so I thought I'd start with the bulbs. That's when I discovered half of them were missing! I replaced all the bulbs today but I've come across a potentially bigger problem. Before, I had brake lights, road lights front and rear and indicator and side indicator all working on the nearside. I also had an offside front road light working. Now after replacing road lights front and rear and side indicator on the offside, and both front road lights, I now have no road lights at all, no brake lights but still have a nearside indicator but only on the rear lamp, the side marker bulb no longer lights. I now also have the offside indicator side marker lighting up when you put the car road lights on and nothing else, and not indicating when you indicate right. I am going to phone my auto electrician tomorrow to see if he can help but can anyone suggest what the possible fault might be? Things to check?
I also have another electrical problem in that my 12V supply doesn't seem to be working. I bought a brand new, fully charged battery and tried to use the on board water pump and the overhead lights. Neither works. I have replaced the tubes in the overhead lights as all looked blown but it still is not working. I may take the battery back to the shop to see if they can double check if it is charged, but failing that, where do I start looking for faults?
Finally, my fridge is not running on a mains supply. I have not tested it on gas yet. While attempting to check for any loose wiring I noticed a plug in a floor cupboard next to the fridge. This had a red LED strip built into the housing. It appears to be wired for a mains spot lamp located in the kitchen area (retro-fitted?) and possibly the cable for the fridge. Is it possible to wire the cable for the fridge to a normal plug? Or is it standard practice? I can't really tell without pulling the fridge out if it does supply it or not but I am going to change the fuse in the plug and check the wiring. Both looked OK from brief inspection today. Again, any assistance in tracing the fault would be most appreciated.
I ran out of time today as I was racing against fading light resealing the awning rails. They were in a bad way and I got very messy! Still, it's done now, and hopefully will get everything sorted before I go away next week.
Thank you in advance for any assistance.
