Habitation Door Alarm Sensor
Mar 21, 2024
6
Good morning , I’ve attached images of where the dealers auto electrician has fitted the habitation door alarm sensor , your thoughts and comments please ?
6,342
I will keep my comments to myself and not run the risk of the Moderators banning me. In a year when we didn’t take our dogs to France I bought some small self adhesive battery operated alarms that went on door and windows. This was because there were dire warnings of entry to vans, and even anaesthetic gases. Needless to say they didn’t get fitted and we are still here. Ever since then two Border Collies followed by two Springers did the job for us.
3,488
32,935
I wonder if sensors have been fitted on the windows as easier to enter by the window than the door. Never seen the need for door or window sensors as we have an alarm in the caravan that is activated by the PIR sensors. We then get a text advising us of the illegal entry.
Mar 21, 2024
6
Hello and thank you for your comment , I agree windows are at risk of entry but no window sensors currently fitted.
The concern with the door sensor is location with risk of standing on it as well as the aesthetics.
6,342
But it doesn’t give warning for entry at night when occupied if that’s what the OP requires.
3,488
32,935
You are correct and they will get damaged quickly. Is there a reason why they were fitted?
3,488
32,935
Hello and thank you for your comment , fitted due to insurance requiring Cat1 alarm system . Why do you think they will get damaged quickly ?
People have big feet. Also moving stuff in and out of the caravan? Never heard of any insurance company requesting Cat ! alarm to be fitted so must be due to location of storage site for caravan? Although recommended there is no requirement to insure a caravan.
Sep 23, 2023
328
93
235
I have no knowledge of alarm systems however a situation transpired that needed a device that came into operation once a seat had been sat on,I used a pressure pad from the now closed "Tandy " that worked admirable,I don't however know if such a device could be of use in the above application.The pressure may was available in various size and was for low voltage use in case 12volt
3,606
Doesn’t look good to me! Has the guy cut away part of door frame? Is it fitted on the hinge or lock side?
My OEM alarm is pir as others have said. Contacts are not needed. Did the Dealer and or Insurer agree the type of alarm with you and explain the installation? Sensors should never be placed I areas where they can become damaged.
Reactions: toad a caravan
2,942
Hinge side looking at the photos,
Jun 6, 2006
710
86
18,935
I could be wrong but it looks like a Motorhome door 🤔
1,805
Hello Raywood, many thanks for your reply , what are the issues with current location and what would be best position for the sensors do you think ?
Thank you
The alarm contacts look vulnerable to being caught by shoes as people enter or leave. I would have thought putting it higher up would be safer.
3,488
32,935
In addition, higher up it would not be so obvious. I wonder if it is connected into an alarm system because if it is, the technician may need to have specialised knowledge of the system.
