Thank you for taking the time to helpHi bouncy and welcome.
I think some have an in-line fuse in the compartment. look there.
Hi rayWelcome to the forum. Normally caravans have the fuse box is under the front right hand seat and they should all be labelled. If it is not please let us have the year and exact model of Unicorn to help identify if it could be somewhere else.
On Googling I found this.Thank you for taking the time to help
Our van is a 2012 Bailey unicorn Barcelona. Not sure if that helps
regards
lym
Well John. I have taken the cassette out.didnt find the fuse but found the reed switch at the back after unscrewing a panel. i found the wiring you spoke of but when I disconnected it. It seems to just be a connector. I think the time has come to take it to a service centre. Again thank you again for you trouble. Kindest regards. LynOn Googling I found this.
This is quite difficult and fiddly. The fuse unit is situated above where the cassette gets inserted. Remove the cassette and at the top front left hand side you will see the wiring in the cavity. This will give you access to the fuse unit and reed switch.
Thank you but no good. Cheers. LynHi Lyn Welcome to the forum if i remember it the fuse is where you insert the cassette and someone else has already put and where to look
hi Lyn hereAh , now I know the model. The fuse was moved to the side wall. See this.Note the red arrow pointing the fuse location. Please let us know how you get on.View attachment 5407
