Hi I’m new and need help. cannot find the fuse for my Thetford c250 toilet .
Aug 24, 2023
5
Hi I’m new and need help. I have a Bailey unicorn and toilet wasn’t flush8ng. After replacing circuit board and pump I’m told it is the fuse. Problem is i can’t find it. Help
1,819
Welcome to the forum. Normally caravans have the fuse box is under the front right hand seat and they should all be labelled. If it is not please let us have the year and exact model of Unicorn to help identify if it could be somewhere else.
2,686
Hi bouncy and welcome.
I think some have an in-line fuse in the compartment. look there.
2,268
Sometimes the impeller gets stuck. You get to it via the flush button. Have a look on You tube. There will be a video. I am told that it is a simple job.
9,133
In three years with my last van I never did find the fuse, and apart from cleaning pcb contacts when it refused to pump one time, it didn’t give any other problems. Although even when the caravan electrics were fully shut down for storage The flush could still be used 24/7 as long as the caravan battery was still in place. Never did find out what the cause was, but admittedly I didn’t spend much time investigating as it was so nice to have something that could be relied upon to work when required, or even when not required.
5,387
The fuse is in side the cabinet containing the waste tank.
Remove waste tank, look to the very back and there it is. Remove fuse , use plent6nof emery paper to clean the contacts. Spray liberally with electrical contact spray. Insert new fuse , correct rating. Should work now.
Reactions: Grey13
Aug 24, 2023
5
Hi ray
Thank you for taking the time to help
Our van is a 2012 Bailey unicorn Barcelona. Not sure if that helps
regards
lym
2,686
regards
lym
On Googling I found this.
This is quite difficult and fiddly. The fuse unit is situated above where the cassette gets inserted. Remove the cassette and at the top front left hand side you will see the wiring in the cavity. This will give you access to the fuse unit and reed switch.
5
Well John. I have taken the cassette out.didnt find the fuse but found the reed switch at the back after unscrewing a panel. i found the wiring you spoke of but when I disconnected it. It seems to just be a connector. I think the time has come to take it to a service centre. Again thank you again for you trouble. Kindest regards. Lyn
Reactions: Jcloughie
2,589
Hi Lyn Welcome to the forum if i remember it the fuse is where you insert the cassette and someone else has already put and where to look
5,387
Ah , now I know the model. The fuse was moved to the side wall. See this.Note the red arrow pointing the fuse location. Please let us know how you get on.IMG_5765.jpeg
Aug 24, 2023
5
Ah , now I know the model. The fuse was moved to the side wall. See this.Note the red arrow pointing the fuse location. Please let us know how you get on.View attachment 5407
hi Lyn here
Thank you for your reply. We had to come home for a couple of appointments. Have left our van in storage. When we pick it up again we will check it out. Again many thanks. Everyone has been fantastic thanks again
