Hyundai Santa Fe mudflaps.
Jun 14, 2009
357
May I request help from other Mk2 Santa Fe's owners. The mudflaps that came fitted to my SF offer little or no protection from stone damage to the front of the caravan. Has anyone had the same problem and managed to find a remedy. On a Kia Sorento forum they suggest fitting Vauxhall Frontera mudflaps to the Sorento, but I'm not sure if they would fit the Santa Fe?
5,114
Hi David
The Vauxhall Frontera mud flaps are not a direct fit to the Sorento. They are the right width and need cutting with a fret saw to the lower shape of the OME flaps. Fixing in between the OME and bodywork is simple enoughThen QED, brilliant.
I would imagine the same principles can be applied to the Santa Fe.
The Frontera flaps were cheap , below
Jun 14, 2009
357
Thanks Dustydog,
I have access to thick rubber conveyor belt the could be used. I am a bit reluctant to go with that, it would look quite ugly I feel.
Feb 15, 2009
300
HI! David why don,t you leave the originals on and buy a cheap nylon door mat from poundland and cut to size to extend your original m/flaps, if you look at the new buses/lorries that are going about that is what they are using (looks very like it to me ).If doing it i would suggest using large washers and small bolts to attach the said nylon extensions .might work . would only cost about
2,127
I'm with Jo Anne, never had a problem wth our 08 plate SF. When daylight arrives tomorow I will double-check the front of the van!
mel
