Improve the visibility
40
The current website is nicely laid out etc. but for those of us with restricted or impaired vision light blue against white e.g. in the Brand Banter section is not easy to read. Similarly the standard typeface as i'm using now could be darker and more bold. The Chrome browser settings enable an overall magnification which helps considerably but an overall review of the site would be appreciated.
If there are user was of changing these i would be glad to know of them
Feb 6, 2009
339
7
18,685
Not sure if this will help or not, but to magnify the size of the elements on screen, hold down the Ctrl Key (on the keyboard) and at the same time move the little scroll wheel ( on top of the mouse) away from you by a click or two....this will magnify the elements you are looking at in your browser.
To make them smaller then hold down Ctrl and move the scroll wheel on top of the mouse back towards you by a few clicks....
After doing this a few times its easy to pick up the knack of zooming in and out at the drop of a hat!
If you want to set the size back to "normal" and your not sure how much to move the scroll wheel then just hold down the Ctrl key and press 0 ( the zero key) and that should do the trick.
If you have tried the "accessibility options" under Windows have you found the way to increase the contrast using the Display settings tab?
Post back if your would like the directions on how to do this....
Regards
paws
