I would have though that increasing the length of the A-frame (hence increasing the distance from the axle to hitch would increase nose weight due to the lever effect?UK caravans tend to suffer more from an inherent high noseweight because they have relatively short A-frames. Their Continental counterparts usually have significantly longer A-frames. As the same chassis (AlKo or BPW) are used industry-wide, both in the UK and on the Continent, the distance from hitch to axle will be the same on both sides of the Channel. However, for given body length, a long A-frame pushes the centre of gravity of the superstructure further back, i.e. closer to the axle, resulting in lower noseweight. The only disadvantage of this is that it increases the overall length of the caravan.
It appears that keeping the overall length of the caravan as short as possible is more important to UK caravan manufacturers than those on the Continent, and that accounts for the problem.
No, because you've got a longer lever supporting the same weight.UK caravans tend to suffer more from an inherent high noseweight because they have relatively short A-frames. Their Continental counterparts usually have significantly longer A-frames. As the same chassis (AlKo or BPW) are used industry-wide, both in the UK and on the Continent, the distance from hitch to axle will be the same on both sides of the Channel. However, for given body length, a long A-frame pushes the centre of gravity of the superstructure further back, i.e. closer to the axle, resulting in lower noseweight. The only disadvantage of this is that it increases the overall length of the caravan.
GF, I'm no expert in vehicle dynamics or design (my "O" Level in physics 40 years ago didn't touch on caravan stability), but I remain unconvinced by your logic. Whether towing or solo, a car with a lot of weight in the boot becomes "light" on the steering, which is something to be particularly avoided when towing. I think where I have a problem with your theory is that it over-simplifies the scenario. A car towing a caravan is a complex arrangement with all sorts of forces being applied in all sorts of directions, and as soon as additional energy is applied to the system (in this case the bow wave of the passing vehicle) the consequences are less than predictable.Mick....You are Right about removing weight from the front axle!!
If you add weight to the rear of the car, most will be transmitted to the road via the rear axle.
The much smaller amount of weight removed from the front axle will transfer to the rear axle. This should not affect the steering, as the car was not balanced until passengers, fuel and boot load were added.
It is the rear axle stability that allows transmission of the opposing forces to counteract the lateral forces the buffeted caravan applies to the tow-ball of the car.
You loading plan sounds good..........Thanks for the link, interesting stuff. I knew that the people at Bath had done this work, but I had never seen the results in that amount of detail. I'll think about this suggestion next time I'm loading up, although on reflection I already carry awning with poles, toolkit, steel awning pegs, crate of bottles, jack, footpump etc in the car, so I guess I'm doing it already. Only difference is that, with only the two of us on-board, I drop the seats and push the heavy stuff forward rather than it being behind the rear axle.
