10 of the best cars for towing caravans in 2023 | Motorpoint
Planning your summer staycation trip? These are the best used cars to hook a caravan up to
www.motorpoint.co.uk
Interesting as most of thsoe cars while capable of towing 2000 or more kg, would be a bit unsafe on motorways at 60mph especially those cars with nose weights below 100kg. One of the cars mentioned has a poor track record and is consistently at the bottom of the reliability list. Strangely they omitted more capable cars that have higher nose weights and a higher towing capacity.10 of the best cars for towing caravans in 2023 | Motorpoint
Planning your summer staycation trip? These are the best used cars to hook a caravan up towww.motorpoint.co.uk
All of the cars mentioned confirm to the EU and UK's requirements for nose load 'S" values of 4% or more of towed weight. So I'm not sure why you think their inadequate in that respect.Interesting as most of thsoe cars while capable of towing 2000 or more kg, would be a bit unsafe on motorways at 60mph especially those cars with nose weights below 100kg. One of the cars mentioned has a poor track record and is consistently at the bottom of the reliability list. Strangely they omitted more capable cars that have higher nose weights and a higher towing capacity.
Whilst certain characteristics of each vehicle will have a part to play in how in control it is whilst towing. The major factor by a large margin to safety of any outfit is the driver and the way the outfit is loaded.
I don't see that any of the featured vehicles are inherently less safe than many other tow vehicles providing they are loaded and driven sensibly.
I am of the opinion that it is not safe for a car with a low nose weight of under 100kg to tow a caravan like a 2000kg Buccaneer which has a maximum nose weight of 150kgs especially if they are new to caravan towing?
I am of the opinion that it is not safe for a car with a low nose weight of under 100kg to tow a caravan like a 2000kg Buccaneer which has a maximum nose weight of 150kg.
Although I agree that noseweight does affect handling characteristics what evidence can you provide that there is actually a direct correlation between it and safe towing? Although most hitches are rated at 150kg, few single axle caravans, and there are plenty with a 2000kg MTPLM, have a noseweight limit of over 100kg.
My previous towcar hat an 80kg noseweight limit and was rated to tow 2000kg. It felt very comfortable towing an 1800kg caravan, which I did for over 7 years.
Most AlKo hitches except older AKS 1300 and 2004 are rated at 150kg but the chassis to which they are fitted are limited to 100kg. As the lower of the two values applies, 100kg is the usual limit. Some of the bigger caravans with BPW or Knott chassis have a 150kg limit.By the way most ALKO hitches in the UK are rated at 100kg and not 150kg. Also you mention experienced towers and not newbies to the game.
Why?I would be pretty certain you are in as much if not more danger from outfits that are by your opinion are wisely matched as you are from those whom you would consider to be unwise.
A study carried out by Delphi in the USA included investigation as to why European noseweights are 4%+ while North America noseweights were 10-15% - they concluded that the greater the noseweight the greater the speed before instability set in - they also concluded the reason for the difference between USA and Europe is that towing speeds are much lower here, below 62 mph, whereas in USA 80 mph is normal.Although I agree that noseweight does affect handling characteristics what evidence can you provide that there is actually a direct correlation between it and safe towing? Although most hitches are rated at 150kg, few single axle caravans, and there are plenty with a 2000kg MTPLM, have a noseweight limit of over 100kg.
It all very well making such an impassioned plea, but you are preaching to the converted. But the reality is the there are new readers who may not have read all the past history on this forum, and they have as much right and indeed need to have information about it.I think we have all done nose load to death, please no more🤪🤪.
I'm surprised that you are having so much difficulty in getting adequate noseweight. As I said, when I picked up my caravan from the dealer its noseweight was no more than 25kg, but now I have no difficulty in getting it over 80kg. With two 11kg gas bottles, the spare wheel and sundry items in the front locker, a table, a couple of chairs, the satellite dish together with its mast and a couple of other items in the front floor lockers within the caravan, the noseweight goes up to about 70 to75kg. If I put the awning on the floor in the front of the caravan too, the noseweight jumps over the 80kg limit for the towbar, so it has to go inside the carI have the misfortune to tow a Unicorn S4 Seville which towed home from the dealer had 31kg on the nose. Now, even fully and correctly loaded it is only 53kg and cannot be increased (believe me we have tried and tried) but it tows perfectly well.
When reversing it on the drive at home and I release the mover buttons it stops and the jockey bounces just off the ground - which might be alarming to some but not to us - now - anyway!
It was tic Prof. In fact only a very short while ago I said the same thing as you just have, about repetitions being an important part of this forum and PCv! On the same hymn sheet👍It all very well making such an impassioned plea, but you are preaching to the converted. But the reality is the there are new readers who may not have read all the past history on this forum, and they have as much right and indeed need to have information about it.
If they ask, they need a balanced response.
It noticeable how when the subject is raised, how some comments keep being brought to the table, which are contentious and not necessarily right or logical, yet when the balancing arguments are made we get the moans of "oh not again."
Is it right that a polarised (and potentially inaccurate or even dangerous response ) is allowed to remain on the thread unchallenged - which new readers might take as being correct?
A classic example then of how humour on a forum can misfire.It was tic Prof. In fact only a very short while ago I said the same thing as you just have, about repetitions being an important part of this forum and PCv! On the same hymn sheet👍
And i guess with a lot of these examples, we're back to the arguments about towing
limits being way over the kerb weight of the car.
Some of the arguments on Facebook groups about it is entertaining. Inexperienced caravanners being advised that their Kuga is suitable to tow a caravan that weighs over 300Kg more than their kerb weight simply because it is legal.
