Is having a VPN worth it?
Sam Vimes
2,682
2,141
12,935
Apologies if you've been asked this before but I'm just trying to ensure you're not wasting money unnecessarily.
How do you know your router is at fault?
5,343
I don't which is why I have unplugged the cheapie UPS unit, just in case that is causing the router to shut down. Unfortunately that could take days before I will really know.
I have since found that that our area will be going full fibre sometime next year so probably best to put everything on hold. It was only by chance I found out from Openreach as I did not think we would ever get FTTP for many years living in a rural village.
Not sure if you can use a FTTC modem/ router for FTTP if we do get FTTP. Do they make routers that can be used for either FTTC or FTTP?
2,710
We had FTTP. Now we have fibre to the home. Promised 1000 mbps. But speed varries between 200 and 450 with lots of excuses from the supplier. But to test properly I need a 1gb wired network. Occasionally I need to reboot to get the best.
But am I better off over the FTTP, no. Except for escaping Virgin.
My connection provides all we need and more. If I take up gaming I may not be so complacent.
9,239
We are finding Virgin to be quite fragile and have lost two sets of recordings in 6 months. Problem is any issues are inconsistent so difficult to diagnose even using Virgins own guidance. The other day the remote didn’t function at all well. Changed the batteries and re -paired it with the box. Still no success, so I used my phone as a remote which worked perfectly. In the meantime I had ordered a new FOC remote from Virgin. Then blow me two days I decided to give the remote another try and since then everything has worked and is stable. Quite frustrating.
2,710
I was with them for years, found the kit and technicians to be fine. But hated the so called customer service.
Sam Vimes
2,682
2,141
12,935
I presume that by the router shutting down you mean it gets switched off...loses power. So your right to remove the UPS to see if that's a problem
As for routers that can handle both FTTC and FTTP, I doubt it but then there are many different makes around.
Sam Vimes
2,682
2,141
12,935
FTTH... Fibre To Home and FTTP....Fibre to Premises are the same thing. Fibre all the way.
1,087
1,026
5,435
There are. Almost any 3rd party router that has an embedded FTTC modem (VDSL2+) is likely to also have the ability to support FTTP using one of its local ethernet ports as an uplink. TP-link and Netgear both fall in this category.
Having said that, FTTC routers (VDSL2+) are rather less common these days as almost all new broadband services are supported using PON (packet optical network) with an Ethernet handoff (usually Gigabit Ethernet) on the ONT (Optical network terminator) in the home. Network vendors are concentrating on Ethernet devices as they are cheaper and more ubiquitous.
3,669
What's the downside of just using the free router supplied by the network provider as part of the initial contract ?
5,343
They generally work, but are almost outdated by the time they are delivered. Wifi 6 has been around for quite a long time and wifi 7 since 2023. Our 6 month old router is wifi 5 and is the second router supplied by provider as the first one went faulty after about 6 months and kept dropping out.
Sam Vimes
2,682
2,141
12,935
If you were experiencing drop outs this could well be a fault on the copper/ali lines or even in the cabinet. We used to get frequent drop outs on the old wired system.
Its been known for BT engineers to fix an intermittent or poor quality line by swapping your lines for someone elses. Eventually what goes around comes around - again.
3,669
Having looked at the box, it seems our year-old free router from Vodafone is Wifi 6 and works fine with our 70 Mbps FTTC - but then we're only connecting a desktop PC, a laptop PC, 2 phones and the TV - and never all at the same time.
5,343
In this case the engineer decided it was the box at fault.
It's all very well having WiFi 6 network, unless you have updated your devices to match it's wasted.
All our devices are Wifi 6 including the TVs.
9,239
Our devices tv included are wifi6 but my iPad is positively ancient and I believe it’s WiFi 5, but it makes no difference at all to my usage of it. It’s not something that I can get too worked up about. But what does irk me is that 4G isn’t that good in far too many areas. That’s where I would prefer to see improvements. Fat chance.
Dec 27, 2022
624
449
2,135
Must be newer devices than mine, laptop, 2 tablets, TV, Chromecast, Roku and one phone aren't. 4k Fire stick, other TV and my phone are. Can't see the point in replacing them as they all get the full speed that the router can receive from outside 200+Mbps.
5,343
The TVs are about 4-5 years old. The tablet, laptop and phones are newer, but still a couple fo years old. Firestick is several months old. As said WiFi 6 has been around for some time.
3,669
Like computers 30 years ago, it's an expensive never-ending task trying to keep up with the latest "standard" in interconnected devices - most people should question the value in doing so.
Reactions: GUMPY
5,343
For some value is not a concern, but convenience and keeping up with the lates technology is a concern. The old TVs that we had were about 15 - 20 years old from when the first flat screens were marketed. With computers, not much of a choice as generally after several years the technology is no longer supported and you have no option except to upgrade plus the fact that it has become very slow and is probe to breakdowns.
3,669
The "latest technology" is just marketing pressure to keep spending money - maybe some people are jinxed and everything they buy is "prone" to breakdowns.
Reactions: GUMPY
