We used to tow a 1250 kg caravan with a 1.8 automatic petrol Astra non-turbo, towing ratio about 97% - it wasn't as good as our present outfit (3.0 turbo-diesel towing 1500 kg) but it was adequate - just had to get used to the high revs on hills and long motorway climbs.Has anyone towed with a petrol car any advice would be great towing a small van around 1300
Yes before diesel became mainstream there's wasn't much alternative to a petrol engine. I've had a range of non turbos, plus Saab 9000 CSE turbo and as Roger said you just have to get used to it. I towed a 1300kg Sprite with a Subaru Forester 150bhp non turbo. It was well within the car's 2000kg limit but with CVT autobox it was forever going up in revs as I touched the throttle. It wasn't bought for towing, so I changed it . But more modern petrols with a turbo have very good torque low down and my recommendation would be not to have a CVT box. Go manual or torque convertor or twin clutch options.Has anyone towed with a petrol car any advice would be great towing a small van around 1300
Expect a significant reduction in mpg when towing with a petrol. But if you donβt do many miles compared to solo itβs not an issue. My last two tow cars were Subaru towing a1300 kg van. The 238 bhp turbo petrol gave better mpg than its 150 bhp non turbo sibling.Thanks all how was the fuel
To be fair, a reduction in mpg or miles/kwh from solo figures is expected whether towing with petrol, diesel or EVExpect a significant reduction in mpg when towing with a petrol. But if you donβt do many miles compared to solo itβs not an issue. My last two tow cars were Subaru towing a1300 kg van. The 238 bhp turbo petrol gave better mpg than its 150 bhp non turbo sibling.
Thatβs what I got with the Subaru Forester non turbo towing 1300kg. The turbo Forester gave nearer 24mpg. In my experience petrol towing gave a bigger percentage reduction in mpg than towing with diesel. But it is what it is.Hi I do about 8000 a yr was thinking I would get around 20 mile to a gallon
Sportage doesnβt have DSG thatβs a Volkswagen group proprietary name. Kia have DCT, but it has similar characteristics.The 1.6T Sportage won't have any issues towing 1300kg van.
Only thing I'd be wary of is DSG transmission they don't like crawling (<5mph) up hills with heavy load eg reversing caravan up a driveway.
I've towed a 1300kg van with a Mazda CX-30 (petrol) which gave me about 44mpg solo and 25mpg towing.Hi I do about 8000 a yr was thinking I would get around 20 mile to a gallon
The same applies to a manual box for any time the speed requries he use of a clutch. At slow speeds a torque converter is a dream, but also a dual clutch auto box in a hybrid such as my Passat GTE also gets round the problem by using the torque of of the electric motor to initiate actual movement before any ICE input may be required this eliminating any clutch slippage.The 1.6T Sportage won't have any issues towing 1300kg van.
From the title of this thread I donβt think that the car being considered is a PHEV, hybrid or mild hybrid. But most of the older members of this Forum probably cut their teeth towing with manual gearbox tow cars and I doubt many were affected by clutch failures as they knew how to manage their machinery.The same applies to a manual box for any time the speed requries he use of a clutch. At slow speeds a torque converter is a dream, but also a dual clutch auto box in a hybrid such as my Passat GTE also gets round the problem by using the torque of of the electric motor to initiate actual movement before any ICE input may be required this eliminating any clutch slippage.
