M4 Closure 24-27 October.
9,080
The M4 will be closed in both directions between junctions 18 (Bath) to 19 (Bristol M32) from 7 pm on Friday 24 October until 6am Monday 27 October. It is the final stage of a new bridge being installed.
Happy travels ☹️
5,350
Happy travels ☹️
That’s me stuffed😢Driving back from Pont Kemys on the Saturday!
9,080
They open one road for you, only to close another. ☹️. Hope there is a sensible alternative route that is not full of motorway traffic.
Nice to dream. 😂
This is the last of the full closures caused by replacement of the worn out bridge. The last ones did cause major problems but the work did all complete on time for the M 4 to reopen on the Monday morning.
640
I think the diversion is via A46 to Pennsylvania then right at the roundabout towards Bristol then Ring Road to M32 and M4, if going West and reverse if going East, worst part is the single carraiageway through Warmley otherwise straightforward depending on volune of traffic.
2,667
Happy travels ☹️
Thanks for the info. I will be needing to use the M5 north and south of the M4 around that time. But will definitely avoid those dates now in case the M5 is affected.
3,901
1,088
......sat stationary on that stretch of the M4 for an hour in August due to a vehicle fire.
You often can't win!
Maybe we have!
Passing that way the following weekend (November 1st) on our way with the caravan to Bridgwater/Burnham carnivals.
9,080
The previous time the M4 was closed for this bridge work the holds ups did affect the Almondsbury junction of M4 and M5 carriageways.
Reactions: Jcloughie
5,350
Thanks Mel.
No problem . Back to the old A40 and A419. Just a more demanding tug, twisty and hilly but 10 miles shorter. We will cope👍
5,350
But still got the Air Balloon problem. Possibly go through Stroud. You can wave as you pass by.
Birdlip to the old Air Ballon was fine two weeks ago. Same old hill but with the speed restriction, it makes no difference to me towing. If shut then yesterday I’d take the Stroud through to Cirencester.
9,080
We went up to the A419 via Air Ballon, not towing, but the traffic kept moving albeit slower than normal. Where filtering was required drivers seemed quite patient. What struck me was the sheer scale of the road building construction works from Air Ballon towards Cirencester direction. Awsome how the topography of the land had been changed.
5,257
Hopefully one of the more competent techies can download it from FB and repost it?
If you right click the image, you should be able to save it to your computer and then repost the image on here after resizing it. (y) :)
