Just purchased a coachman 460 VIP 2016 I am unable to find the wheel jack looked in all the obvious places, is there a hiding place for it?
Any help would be great.
I brought it from the late persons estate.If you have just purchased it, I suggest you contact the seller and ask.
Many Many Thanks for taking the time to explain this was very helpful.👍I bought my Coachman VIP 575/4 new in 2016 and it came with everything, except for a jack, jacking points or any other means of changing a wheel on the caravan. Unfortunately, you will have to buy a jack and if you go the Al-Ko side jack route you will have to buy the jacking point brackets too. Fortunately your caravan's chassis will have the holes present to mount the said brackets.
The Al-Ko side jack is very similar to the jack many cars have. I only ever used it to get the Al-Ko wheel lock fitted or to get a Lock "N" Level under the wheel, when I was experimenting with faster way of achieving either task. All it really proved was that the jack never inspired me with confidence, it needed quite a bit of effort to jack the caravan up and always seemed a little bit wobbly. If I needed a jack in future I would look at the "KOJACK" from Purpleline.
Moving on, if you have only just bought your caravan I strongly recommend you remove the spare wheel from the Al-Ko underslung carrier, if that's where your spare is located. If it hasn't received regular attention I can guarantee you will struggle with the carrier itself, the spare wheel retaining nuts will be rusted solid, the steel spare wheel will also be going rusty and the tyre will have sidewall damage from the tubes of the carrier. You don't want to find any of this out in an emergency. I've removed the carrier completely, given the spare wheel some TLC and it now lives in a bag under the bed.
Finally, check the date of manufacture on your tyres, they could be potentially over seven years old if they haven't been changed. The general recommendation is that they are changed at five years. Although it's not law, some insurance companies insist on this.
Sorry to be the bearer of less than good news but, I honestly believe that after 2016-17 the quality of caravan construction including Coachman has declined due to the massive increase in demand. For that reason I wouldn't swap my Coachman for another or for any other make at the moment.
Enjoy your new caravan, you have made an excellent choice.
