New Control panel gone off cannot get it to come on (There must be a fault somewhere)
2,577
At present we have these working Sockets , Microwave , Tv 2 Lights
i have checked the MCB the lever was up so it had not tripped
i have retested it to make sure .
the fridge , water tap spotlights toilet flush is a no go
is there something i am missing ?
2,577
We had a brand caravan battery as well
But could there something wrong with 12 volt system that at fault
i have sent for a mobile caravan technician to come .
2,577
Hi Damian the make is a 2008 Abbey GTS 215 Touring caravan have you work on one of these any suggestions what is wrong
937
Hi Beachball, I think your van has the Nordelettronica power system and it would seem that it has done what they are known for,,,,,,malfunctioned.
I would just check to see if you do have the Nord system, and if so, give Paul or one of his team at Apuljack Engineering a call tomorrow.
Here is the info to contact them: http://www.apuljackengineering.co.uk/contact.html
2,400
Beachball has recently had a new control panel fitted and a new leisure battery.
It could be the battery charger.
If the leisure battery is flat the control panel won't work.
937
Yes it could be just that, or the battery is fine and the relay that is supposed to switch in has failed and has isolated the battery from the van, and stopped the connection with the charger.
2,577
Hi
The caravan technician giving us a ring in the morning so i could pass this onto him he should be able to fixed it i hope .
i have ask him to check the battery to see if it Flat
Thanks for your help Damian & Parksy
Reactions: Parksy
2,577
Yes we do have the Nord system . I have check the details out and if we need Paul i will ring him thanks .
Oct 3, 2013
890
90
18,935
Hi,
Circuit breakers only protect ac circuits not dc circuits.Check your fuses in particular the battery fuse (Usually rated at 20A and located near the battery box) dc circuits are protected by fuses might as well check them also.
To check your Nord thingy if you can put a voltmeter across the battery then switch on the nord unit - the battery voltage should go up,not a lot but it should go up
2,577
Hi,
Actually we check the battery fuse that was ok but we are home now after the quickest 14 day break only had 2 days . the caravan going in tomorrow and i leaving it with him until he check everything on the 12volt system
4,574
Thats not good news for you, hopefully Rutland might give you a credit to go back another time.
2,577
Hi Hutch Actually we are hoping we can transfer it to bit later in October i might send a email or ring in the morning see what they say .
2,577
Latest news
Manage to change Rutland Caravan and camping they transfer it for me
Sunday 11th October for a few nights
