Hello all,
After making repairs to the 12N and 12S plugs on our 1993 Swift Corvette Diamond (thanks again storm Gertrude), I took the opportunity to hook up the car, and test the supplementary circuits, something I have never had the time to do since we started this whole caravanning rollercoaster ๐
I discovered that, whilst we are getting a constant 12v across pin 4 (green) which I think provides the power to the caravan for lights etc, and an ignition 12v across pin 6 (red), which powers the fridge ?? I am getting no feed, permanent or otherwise, to pin 2 (blue), which I think should be charging the battery when we are driving.
(I had a battery meter monitoring the battery voltage whilst carrying out the checks, and it appears we are getting no charging)
I have checked all the fuses, and everything looks in order.
I then turned my attention to the car, and wonder if the fact that the car has a 13 pin socket, which we access via a 12N / 12S to 13 pin adapter, could be a factor ?
Can anyone advise if a 13pin socket on the car (assuming it has been wired correctly) connected via an off-the-shelf adapter, should provide a 12v feed to pin 2 on the 12S plug ?
Is there something else I may have overlooked in this problem (I am not a qualified electrician, more of a keen DIY`er)
Many thanks
Many thanks
