No pressure in taps and no power showing on DC
Jun 28, 2014
19
I'm living an my caravan at the mo while work getting carried out on house, the power is coming from the house by electric hook up and the dial has always been showing about 13v so been working perfect but got up this morning and the dial is not showing any volts at all now and also got no pressure to the taps just a trickle what could of happened do you think??? Thanks
Jun 28, 2014
19
Sorted... Hahaha ...don't dare say but , water barrel went empty unbeknown to me lastnight pump ran until battery was real flat hence the low pressure in the taps, just boosted it with the jump leads and then job sorted!!!
Jun 28, 2014
19
False alarm, it's gone flat again and for some reason the charger isn't charging it back up again wonder if something could of happened to that!!!???
Jul 15, 2008
3,648
675
Do you know for sure you have a mains power supply from your house?
Are you using other mains appliances in your caravan?
You know what builders are like........... they may have isolated your supply!
