Parksy
Or a red herringAbsolutely not. My problem was with you failing to understand that it was just an analogy.
Well, red herring or analogy, my link to RIDDOR has clarified what the acronym means for those who didn't know.Rather insulting.
But.
No, analogy. Simple.
Spot on Custard. Both my local dealers have virtually zero used caravans for sale...
Strange very few newcomers have been on here or the other caravan forums?
The speed limit isn't a target, drive to what you can see and within your capabilities and let the loonies get on with it, they'll be the ones who don't keep everything shiny side up.
We could count the white lines versus time elapsed !!!😂For all we know is that you could have been plodding along at 40mph holding up the traffic which then makes the Buccaneer look as if it is passing at warp speed. To get the correct perspective one would need to see your speed. 🙂
The only time I exceed the 60mph when towing on a motorway is when overtaking otherwise my cruise control is set to 58mph.Mine does record speed, time and location. This can be turned off. This function when used in support of an accident is very useful, but. If you had a no fault a accident and you used the footage to support your case, if you were just slightly exceeding the speed limit, this could go against you.
I chose to record the info. I rarely exceed the limit but must admit I struggle with the lower ones. And I I did need to submit it I would blur the incriminating evidence out.
I think Custards video shows very little and was probably much different live.
Looks like transporter braked as he was approaching the smaller car in lane 1 and to have pulled out in front of you would be unsafe.
Merc looked nice and stable though. Doesn’t dash cam record and display
speed?
Merc looked nice and stable though....
Doesn't look like a bad piece "cutting up" to me . The small car overtook the transporter and went in the transporter did not show any brake lights at that time. Brake lights came on when the transporter driver realised that he could not move into lane 2 as you were approaching. But by then the small car was pulling away from the transporter. At least the transporter did carry out the instantaneous 3M where by some wave of the wand it was suddenly all transposed sideways into lane 2.It does but the app to control it stopped working (It has no screen) when I changed phone, but it records ok so had no need to fix it.
The Car was behind the Transporter, overtook then cut it up.
I was at a GPS speed of 60.
We will be new caravanners from next week when we pick it up. I have spent the last 2 weeks researching, reading forums like this and found the information invaluable. I for one will heed the rules, stay within the law and tow safely, there’s no other sensible way with loads like ours. Then there’s the ones with no sense......Not just the rules (e.g. different speed limits for towing), but the guidance as well (e.g. correct nose weights, correct attachment of the breakaway cable etc).
The trouble is, if no-one has got hold of these guys at the at the start of their caravanning career, to encourage them to find out the things they need to know, then it becomes more and more likely that no-one will. If someone starts caravanning and doesn't see the need to research to find out if there are things they need to know - things they haven't even thought of - then after their first trip, when nothing has gone wrong, that opinion is re-inforced. And more so after each subsequent trip.
Had my satnav do similar in Burford. I’d set it to shortest distance as opposed to quickest. Luckily no caravan in towGoing back a few years now, and no dash cams or come to think of it, not many mobile phones either....
M5 just hitting Bristol going north... I'm middle lane a caravan hammers past me on the outside lane... I still do not know how the driver managed the next bit...
Traffic is reasonably heavy, the caravan had over taken me on the 3 stripe exit distance marker... At the 2 strip the caravan was still on the outside lane, at the1 strip marker still on the outside lane, at this point he went cross all lanes of triffic to exit...
As I say, I still don't know how he (an assumption) managed in such a short distance to go from the outside lane, across two lanes to exit the motorway at full pelt, without being hit or jackknifing or snaking the caravan....
I'm a wimp when it comes to overtaking with the caravan hitched, this is to be avoided unless I'm overtaking a park vehicle....
But I am pleased to say, being caught out by my satnav, which took me through Shrewbury, due to road works, it wasn't a case of straight through the main street, but taken off the main road, around and down a side road if that little feat was bad enough, coming back out on to the main road, I had to get the car and caravan onto the narrow high street with bollards on each side of the side road! without hitting a shop window etc... I managed it then some muppet in a BMW was parked on the double yellows, so a very tight fit, between shop windows etc. With a police car waiting at the top of the road 🙄
Horror turned to relief when I got up to the police car, to see two coopers grinning like two cheshire cats giving me the thumps up
