- Aug 1, 2005
- 6
- 0
- 0
Just taken delivery of a new to us van. Weve never had on board tank before and would appreciate hints on draining for winter, do we drain the tank before travelling and any other hints would be much appreciated.
Sorry about the echo..It is not recommended that you tow with water in your on board tank Chris. Having said that I have on occasion left a few litres in there, to be able to make a cup of tea on a long journey. If that's your idea then check your nose weight before setting of, water is quite heavy and it might be easier to take water in a separate container. You should have a drain tap somewhere close to the tank, I know exactly where it is on a Senator but you don't mention which van you have. If I am laying the van up for winter, the last time I tow with it I open the drain and taps, the act of towing will release all the water in the tank so that it is completely empty when I get home. It is a good idea to run a caravan sterilisation fluid through your water system including you is tank, before you use it.
