Buckman I think its the Chassie that cannot exceed 7 meters , not including the A frame, look at the length of some glider trailers.
The length limit for caravans is , as Buckman has said, 7 Mtrs body length, excluding the A frame.
However that will probably increase the body length of the caravan?I think that a much better way to implement aerodynamic improvement would be to offer caravan manufacturers the results of your research with a view to integrating the proposed form into the design of the front end of the caravan itself. That way, one wouldn't need a separate device which would have to be specific for each caravan style and solve the problem of storing such a big item when not needed. Besides, the on-cost for an integrated design would be a lot less than for such a separate "accessory" item.
Of course, but it could be put to good use by providing more storage space.However that will probably increase the body length of the caravan?
